Thread: VW Sharan Electric Window Malfunction
  1. Arrow VW Sharan Electric Window Malfunction
    di4charles Guest
    Hello,
    The rear passenger offside window in my VW Sharan (Nov 2001 New Shape) will no longer open - it simply stopped working one day and has not worked since - it will not work with either the driver's switch or the passenger door switch. All other electric windows are OK. I was wondering if anyone had suffered the same problem and if there was an easy solution that I could manage to fix myself. I am happy to remove door trim or renew relays, etc. Any ideas anyone?
    Thanks and Best wishes,
    Charles
  2. Re: VW Sharan Electric Window Malfunction
    May 2008
    wirral
    you need to trace your loom from window switch to the gater rubber in door joint may have slight brake in wire through streting or just age...in my opinion not the switch as it would work from drivers door...also check under pass seat for any water maybe if so them relays could be your problem...just a thought...
  3. Re: VW Sharan Electric Window Malfunction
    Dec 2007
    Suffolk
    Check the wiring for breakages in the rubber boot that goes from the body to that door
  4. Re: VW Sharan Electric Window Malfunction
    di4charles Guest
    Thanks, I will check out both these suggestions and let you know...
  5. Re: VW Sharan Electric Window Malfunction
    Dec 2008
    Stockport
    I have exactly the same problem, can you let me know what you found as the cause?
  1. Sharan electric window replacment
    By ciaran in forum Touran - Sharan - Caravelle
    Last Post: 02-09-2008, 04:39 PM
  2. Sharan nsf electric window problem
    By colinwdick in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2008, 11:51 PM
  3. Please Help sharan,05,90bhp ,diesel, drivers electric window problem
    By 2mtec in forum Touran - Sharan - Caravelle
    Last Post: 21-05-2008, 12:44 AM
  4. Sharan electric window problems
    By garym in forum Chat - Anything with wheels
    Last Post: 04-05-2008, 05:53 PM
  5. Sharan electric window, passenger side
    By paulnh in forum Touran - Sharan - Caravelle
    Last Post: 21-06-2007, 08:37 AM
