Thread: Gear Stick Gaiter Removal
  1. Question Gear Stick Gaiter Removal
    Aug 2007
    Just a quick question
    Does anybody know how to remove the plastic trim that holds the gaiter down. I can see two tags at the back and I can get one side to pop out but there must be one at the from somewhere?
    Cheers in advance
    Mitch
  2. Re: Gear Stick Gaiter Removal
    Nov 2006
    Got it off. There are three plastic tags, one at 3 O'Clock, one at 6 O'Clock and one at 9 O'Clock that stick out. These tags are attached to the clicps that hold the surround down. Pulls all the tabs in towards the gear stick and lift up. Really annoying as I tried forever to push the sides in and the bottomm at the same time but the way the tags are designed, they have to be bulled back. I did however manage to stap the one at 6 O'Clocks as they are very flimsy so beware
  1. Changing a MK4 Gaiter + (Gear Stick problem )
    By Dirtdiver in forum Golf MK4 - 1999 - 2004
    Last Post: 21-08-2008, 10:22 PM
  2. Gear Stick Gaiter
    By vw77 in forum Touran - Sharan - Caravelle
    Last Post: 23-06-2008, 08:54 PM
  3. Sharan: Replacing Gear Stick Gaiter?
    By di4charles in forum Touran - Sharan - Caravelle
    Last Post: 25-03-2008, 12:04 PM
  4. Gear gaiter removal
    By pa ousman in forum New Member Introductions
    Last Post: 08-12-2007, 04:48 AM
  5. A3 removal of Gear stick 1.8 20vT 97 p
    By chocoboy in forum Audi A3 - Archive Topics
    Last Post: 26-02-2007, 01:23 PM
