Thread: Intermittent blowing fuse on fuel pump circuit
  1. Intermittent blowing fuse on fuel pump circuit
    Fuse keeps blowing on fuel pump circuit, sometimes 3 times a day, then it's OK for 10 days. I've changed the fuel pump ans fuse lasted 7 days, no obvious signs of any cable damage. Any ideas? It's a 20A fuse now, and has other things on the curcuit like injectors I think.
    1.0 '94 Polo.
    Quote Originally Posted by Clavdivs View Post
    1.0 '94 Polo.
    How about removing the earth strap on the front right of the battery behind the headlight and cleaning it with sandpaper as they rust easily and then and check&prefrably clean all other earths the same way but apply a little copperslip to all earths to keep corrosion at bay.check the rear tail light earth(near right cluster) and make sure the taillight seals dont allow water in as the bulbs corrode and cause shorts or high resistance on the posotive circut also.remove and check all bulbs.last is the fuse box and its earth,is everything secure and not coroded as damp areas in the footwell can help rust along in winter with the heater on.
  1. ECM Fuse blowing
    By mikespain in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 01:08 PM
  2. 1993 90CS 2.8L- Fuel pump fuse keeps blowing
    By pipflop in forum Chat - Anything with wheels
    Last Post: 25-04-2007, 08:19 AM
  3. fuel pump
    By bilal aslam in forum Touran - Sharan - Caravelle
    Last Post: 08-03-2007, 02:43 PM
  4. Passat Fuse 14 blowing
    By zorgie in forum Passat - Archive Topics
    Last Post: 20-06-2006, 10:48 AM
  5. BORA fuses blowing ? Which fuse how many Ampere ?
    By henri in forum Bora - 1998 - 2005
    Last Post: 22-02-2006, 11:23 PM
