Thread: Electrical fault
Results 1 to 10 of 10
  1. Electrical fault
    Sep 2008
    Hi all,
    Firstly i want to say what a great site. This is my first post so please bear with me.
    I have purchased an Audi A8 (2004) which is a dream and until recently seemed to be running fine. Then while driving the electrics on the dash start to go beserk and all lights were flashing (incl headlights/side lights), and the radio also cuts out. I pulled over and after a short wait restarted the car and all worked fine, until about a week later when the same thing happened again (most recently Fri 29 Aug).
    Really worried as not sure what could be cause. I have taken a VAG scan and found various fault codes storted which i have listed below, but not sure what they all mean other than they all suugest some sort of electric problem> Can anyone see if they can see possible cause of problem and let me know how i can fix. Thank you all.
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4E0 910 401 H HW: 4E0 907 401 B
    Component: 3.0L V6TDI G000AG 0050
    Revision: --H01--- Serial number: AUX3Z0D3140167
    Coding: 0011773
    Shop #: WSC 00052 210 88667
    1 Fault Found:
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 167.7 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 12.16 V
    Bin. Bits: 00101111
    Torque: 89.7 Nm
    Temperature: 86.4°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4E0 910 156 F HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0050
    Revision: 00000001 Serial number: 0016668
    Coding: 0000001
    Shop #: WSC 02313 785 00200
    No fault code found.
    Address 03: ABS Brakes Labels: 4E0-910-517.lbl
    Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
    Component: ESP 5.7 allrad H44 0500
    Coding: 0008357
    Shop #: WSC 02313 000 00000
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - - - Intermittent
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 909 131
    Component: FBS AUDID3 H03 0140
    Revision: 01403903 Serial number: AUX3Z0D3140167
    Coding: 0264192
    Shop #: WSC 02311 785 00200
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 165
    Mileage: 88672 km
    Time Indication: 0
    Date: 2007.10.25
    Time: 23:37:48
    Address 06: Seat Mem. Pass Labels: None
    Part No SW: 4E0 910 760 C HW: 4E0 959 760
    Component: Sitzmemory BFS H08 0060
    Revision: 00000000 Serial number: 5DS 008 795-03
    Coding: 3670112
    Shop #: WSC 00000 785 00200
    Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
    Part No SW: 4E0 910 732 A HW: 4E0 035 729 A
    Component: Interfacebox H43 4220
    Revision: 00000000 Serial number: 300DE047535119
    Coding: 0000002
    Part No: 4E0 910 609 A
    Component: Bedienteil MMI H42 0020
    3 Faults Found:
    01327 - Control Module for Parking Aid (J446)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 154
    Mileage: 94367 km
    Time Indication: 0
    Date: 2008.08.24
    Time: 18:56:03
    01317 - Control Module in Instrument Cluster (J285)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 154
    Mileage: 94367 km
    Time Indication: 0
    Date: 2008.08.24
    Time: 18:57:08
    Freeze Frame:
    Bin. Bits: 01
    01310 - Level Control System Control Module (J197)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 154
    Mileage: 94367 km
    Time Indication: 0
    Date: 2008.08.24
    Time: 18:57:14
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
    Component: KLIMAAUTOMAT 016 0300
    Revision: 00000025 Serial number: 00000000042318
    Coding: 1067009
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
    Component: ILM Fahrer H12 0190
    Coding: 0100001
    Part No: 4E2 910 113 B
    Component: Wischer WWS D3 H50 0420
    Coding: 00000000
    Shop #: WSC 02313
    1 Fault Found:
    02071 - Local Databus
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 160
    Mileage: 94444 km
    Time Indication: 0
    Date: 2008.08.27
    Time: 18:41:45
    Address 15: Airbags Labels: 4E0-910-655-84.lbl
    Part No SW: 4E0 910 655 HW: 4E0 959 655 G
    Component: Airbag 8.4E+ H10 0940
    Coding: 0431707
    Address 16: Steering wheel Labels: 4E0-910-549.lbl
    Part No SW: 4E0 910 549 HW: 4E0 953 549
    Component: Lenksäulenmodul H13 0040
    Coding: 0112041
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 900 HW: 4E0 920 950 A
    Component: KOMBIINSTR. VDO H44 0090
    Revision: D15 Serial number: AUDID3D3001478
    Coding: 0000403
    Shop #: WSC 80093 222 69422
    Address 18: Aux. Heat Labels: None
    Part No SW: 4E0 910 105 HW: 4E0 815 069 D
    Component: Heizgeraet H06 0300
    Revision: 0000000G Serial number: 00000009001484
    Shop #: WSC 00000 000 00000
    2 Faults Found:
    01406 - No Flame
    00664 - Fuel gauge
    Address 19: CAN Gateway Labels: 4E0-910-468.lbl
    Part No SW: 4E0 910 468 HW: 4E0 907 468 A
    Component: Gateway H07 0070
    Revision: 07 Serial number: 1600304326053D
    Coding: FCFE5BDE2B3504
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBD4022223
    Address 25: Immobilizer Labels: 4E0-910-131.lbl
    Coding: 0264192
    Component: ELV XXXX
    XXXXXXXXXXX ELV XXXX
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 165
    Mileage: 88672 km
    Time Indication: 0
    Date: 2007.10.25
    Time: 23:37:48
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
    Component: LUFTFDR.-CDC H05 4290
    Coding: 0015510
    2 Faults Found:
    01316 - ABS Control Module
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 161
    Mileage: 93940 km
    Time Indication: 0
    Date: 2008.07.05
    Time: 21:23:36
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 160
    Mileage: 94372 km
    Time Indication: 0
    Date: 2003.10.08
    Time: 00:00:21
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzmemory FS H08 0060
    Coding: 3670114
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 T HW: 4E0 919 887 C
    Component: MNS ECE H43 1030
    Revision: 00000000 Serial number: 353DL047514247
    1 Fault Found:
    00447 - Function Limitation due to Over-Voltage
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 94471 km
    Time Indication: 0
    Date: 2008.08.29
    Time: 19:37:13
    Freeze Frame:
    Hex Value: 0x48B8
    Hex Value: 0x4FE9
    Hex Value: 0x00B8
    Address 38: Roof Electronics Labels: 4E0-910-135.lbl
    Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
    Component: Dachknoten D3 H01 0090
    Revision: noten D3 Serial number: 00000409800047
    Coding: 0035968
    3 Faults Found:
    02166 - Reference Signal for Front Windshield Temperature Signal
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 0
    Fault Frequency: 15
    Reset counter: 155
    Mileage: 93344 km
    Time Indication: 0
    Date: 2008.06.14
    Time: 12:50:00
    01370 - Alarm triggered by Interior Monitoring
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 155
    Mileage: 0 km
    Time Indication: 0
    Date: 2003.10.08
    Time: 00:33:00
    Freeze Frame:
    Bin. Bits: 00000000
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 94468 km
    Time Indication: 0
    Date: 2008.08.29
    Time: 19:37:00
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 4E1 910 802 HW: 4E2 959 802
    Component: Türsteuer.FS BRM007 0110
    Coding: 0028462
    1 Fault Found:
    01340 - Mirror Adjustment Switch
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 155
    Mileage: 94368 km
    Time Indication: 0
    Date: 2008.08.24
    Time: 19:20:06
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 A HW: 4E0 907 289
    Component: Komfortgeraet H04 0040
    Revision: 00400004 Serial number: W040404210067
    Coding: 0005373
    Shop #: WSC 00052 210 83205
    Part No: 4E0 910 853
    Component: Heckdeckel P14H06 0070
    Part No: 4E0 907 719
    Component: Neigungssensor H03 0020
    Address 47: Sound System Labels: 4E0-910-223.lbl
    Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
    Component: DSP-Amp.-High H13 0440
    Revision: PROD_01 Serial number: 00000000001371
    Coding: 0000013
    Address 4F: Centr. Electr. II Labels: None
    Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
    Component: ILM Beifahrer H09 0040
    Revision: Serial number: 00000000038965
    Coding: 0010001
    1 Fault Found:
    02072 - Control Module for Energy Management (J644)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 162
    Mileage: 0 km
    Time Indication: 0
    Date: 2023.06.06
    Time: 00:00:00
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 4E1 910 802 HW: 4E2 959 801
    Component: Türsteuer.BF BRM007 0110
    Coding: 0028462
    Address 53: Parking Brake Labels: 4E0-910-801.lbl
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000221
    Shop #: WSC 00958 210 12835
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4E0 035 541 B
    Component: TUNER EU/US/RDW H41 0620
    Revision: 00000000 Serial number: 304DV047586657
    Coding: 0000001
    Address 57: TV Tuner Labels: 4E0-910-146.lbl
    Part No SW: 4E0 910 146 G HW: 4E0 919 146
    Component: TV analog TUNER H12 0300
    Revision: 00000063 Serial number: 00000000002032
    Coding: 0001003
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 94471 km
    Time Indication: 0
    Date: 2008.08.29
    Time: 19:37:12
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 B HW: 4E0 915 181
    Component: ENERGIEMANAGER H02 0240
    Revision: 00000000 Serial number: 00000002031636
    Shop #: WSC 00509 210 14479
    Part No: 000 915 105 AK
    Component: von VA0 2403290271
    Coding: 303030393135313035414B56413032343033323930323731
    Shop #: WSC 00000 128 00289
    4 Faults Found:
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Mileage: 90140 km
    Time Indication: 0
    Date: 2007.12.30
    Time: 16:12:52
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Mileage: 90140 km
    Time Indication: 0
    Date: 2007.12.30
    Time: 16:13:03
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 5
    Mileage: 90140 km
    Time Indication: 0
    Date: 2007.12.30
    Time: 16:13:13
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 4
    Mileage: 90140 km
    Time Indication: 0
    Date: 2007.12.30
    Time: 16:13:23
    Address 62: Door,Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 HW: 4E0 959 801 A
    Component: Türsteuer.HL BRM007 0110
    Coding: 0028462
    Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 HW: 4E0 959 802 A
    Component: Türsteuer.HR BRM007 0110
    Coding: 0028462
    Address 76: Park Assist Labels: 4E0-910-283.lbl
    Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
    Component: Parkhilfe 8-Kan H12 0020
    Revision: --.--.-- Serial number: 08730410705093
    Coding: 0001008
    Address 77: Telephone Labels: 4E0-910-333.lbl
    Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
    Component: TELEFONMODUL EU 0770
    Revision: 00000006 Serial number: T2AUD31011HC7W
    Coding: 0000004
  2. Re: Electrical fault
    May 2007
    knee deep in clunge
    14 Post(s)
    Ok a8 networks are very complex.First you need to address the battery management issue and recharge the battery
    also the lin signal is a worry
    Coding: 0100001
    Coding: 00000000
    Shop #: WSC 02313
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 160
    Mileage: 94444 km
    Time Indication: 0
    Date: 2008.08.27
    Time: 18:41:45
    Please clear all fault codes and recharge the battery and then after using the vehicle run another scan as there are to many under voltage fault codes stored and to many old code stored,concentrate on the august 2008 codes and this will narrow the diagnosis to a manageable level
  3. Re: Electrical fault
    Sep 2008
    A8 Tech - thank you for such a quick response- i will definately recharge the battery and let you know how i get on. I know this may sound silly but by disconnecting the battery (for the recharge) will i need to do any sort of resetting, or is it simpy a case of reconnecting after recharge and then rescan?
    thanks
  4. Re: Electrical fault
    May 2007
    knee deep in clunge
    14 Post(s)
    OK don't disconnect the battery,if you look at the negative terminal you will see the short earth lead goes to the battery manager control unit,there is a negative post there and that's the charging point as the manager measures the amps also if you replace the battery it requires recoding to calculate charge rate.As i mentioned A8 is a very complex car and the battery manager will slowly shut the cars systems down on the returning amps calculation to the battery.The battery needs to be charged correctly and in circuit to prevent further red hearing fault codes.I cant offer a full answer about the how to and how it works as there's not enough space on the forum but if you have the battery display in the mmi functions it will offer a fairly accurate consumption level.If you don't have the display i will tell you how to adapt the mmi set up to show the battery state.The dash communication fault also concerns me but it will become clear when the fault codes have been erased.Also always attach the battery charger when carrying out any electrical work as the battery drain on a8 is very quick and you may be draining the battery with out noticing by having the door open whilst using vag com
  5. Re: Electrical fault
    Sep 2008
    A8tech, I do not have the battery indicator on the MMI so if you can tell me how to get that adaptation done i would appreciate it. I will then charge up the battery( without disconnecting!!) and then post back result of how i get on.
    thanks again for taking the time to respond.
  6. Re: Electrical fault
    May 2007
    knee deep in clunge
    14 Post(s)
    Go to address 07
    go to adaption channel 02 the self help balloon should highlight your choices and you need to add battery level to the adaption value and save.
    Reset the mmi by entering into adaptions again and enter channel 111 and follow the prompt to restart the mmi and this will then allow the battery display to load into the car set up functions.
  7. Re: Electrical fault
    Sep 2008
    A8 Tech,
    I have tried to make the change to the MMI settings per the instructions you supplied and got as far as getting to address 07, and then to channel 2, but after that there was no self help ballons
    The adaption value was showing as 18, but have no idea how much i need to change that value up or down by. I am using Genuine Ross -Tech USB HEX- CAN cable and version 805 of VCDS.
    Sorry to be a pain.
    I had a quick search of the forum as well to see if this has been answered before but did not find anything. I will do the battery charge in anycase and post update.
  8. Re: Electrical fault
    May 2007
    knee deep in clunge
    14 Post(s)
    add value 32 to channel 2
  9. Re: Electrical fault
    Sep 2008
    A8 Tech :
    Thanks for all your help with the above. I now have the battery meter on the MMI following your instructions, and I cleared all the old fault codes and did the recharge of the battery as well. I did notice that the +ve connector was not tight, ie connected but could move around easily so tightened that as well (not sure if this could have been the cause of the problem?)
    After recharging the battery for 4 hours today took the car for a quick short drive, and then did a rescan, and thankfully no faults found, with the only unexplained item being the label description on the following, which i am not sure if i need to worry about?:
    Coding: 0011773
    So fingers crossed, all resolved now, but the real test will be over the next few weeks on longer drive! Thanks again
  10. Re: Electrical fault
    May 2007
    knee deep in clunge
    14 Post(s)
    no problem
  1. Electrical fault
    By YodaTheCat in forum Golf MK3 - 1993 - 1999
    Last Post: 19-08-2008, 05:46 PM
  2. Electrical Fault
    By blaggie in forum Golf MK4 - 1999 - 2004
    Last Post: 12-08-2008, 07:37 PM
  3. electrical fault
    By revres in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-11-2007, 09:26 PM
  4. Electrical fault?!
    By SCORCHIO12 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2007, 11:45 AM
  5. T Reg Passat - Electrical Fault, Remote Central Locking Fault
    By adriana in forum Passat - Archive Topics
    Last Post: 01-03-2007, 06:27 PM
