Thread: Buying A4Cab 53 plate 3.0 V6 Sport
  1. Buying A4Cab 53 plate 3.0 V6 Sport
    Jul 2008
    Hi guys
    I am looking at buying a4 cab 3.0 V6, Is there anything I should ask about or look out for?
    I guess checking the electrics (like the boot lock) and that there is no fraying in the hood or round the rear window.
    Any comments welcome, especially about the engine.
    p.s got a Ibiza cupa for sale if anyone is interested?
  2. Re: Buying A4Cab 53 plate 3.0 V6 Sport
    Mar 2007
    Oxfordshire
    I was going to go for the 3.0 but got the 1.8 instead (a good quattro turned up) - and actually very pleased with it. I would aim to pay around £8.5K for a 2004 model with around 45K, full leather and get the sport model. I personnally avoided the multi-tronic, I think that was a good move... Make sure it's been well looked after - pretty much the same as any car. I always look at the previous owner - ie is he a boy racer or a rich guy who spent money on the car when it needed it... Let us know what you find!
  3. Re: Buying A4Cab 53 plate 3.0 V6 Sport
    Apr 2007
    Worcestershire
    When I was looking I found that:
    The roof storage compartment lever in the boot didn't retract all the way up on a few I saw.
    Check that the glovebox door isn't too stiff as if it is - these have a tendancy to snap at the hinge and then the whole glove box needs to be replaced!
    Be very wary if its a Multitronic gearbox as they are prone to fail if the oil hasn't been replaced regularly and are expensive to get fixed.
    The V6 3.0 or 2.4 can't be remapped/modified whereas the 1.8T can.
    Check the Econ red light goes out and stays out once pressed - otherwise the Aircon needs looking at.
    Try and get one with as many extras as posible - Heated seats a must - Bose stereo v good - and avoid 16" rims!
    Having owned mine for nearly a year - in my opinion, out of the full range (upto 05) I'd go for the 1.8T Quattro.
  4. Re: Buying A4Cab 53 plate 3.0 V6 Sport
    Sep 2007
    UK, North East
    Electrics are everything. Check windows, heater, air con, roof etc.
    If you get multitronic listen for any knocks at all, also check reverse engages with no problems and test the tiptronic works ok. Any gearbox issues, run a mile.
    Theres some bargains to be had out there currently but remember you're due a cambelt at 5 years so will be shelling out best part of £500 straight away if its not already done.
    Also check FSH is genuine. And the obvious engine checks for mayonaisse etc although a small amount of milkiness on the filler cap is expected in these engines apparently due to the thinness of the oil.
  1. using biodiesel in tdi sport, 55 plate b6
    By ianth in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-09-2009, 09:50 AM
  2. Question Possibly buying 53 plate 225 Cupra R
    By SEMKY in forum Leon
    Last Post: 05-10-2008, 08:06 PM
  3. buying a A3 TDI 2.0 SPORT
    By nickbrice in forum Chat - Anything with wheels
    Last Post: 11-02-2008, 12:47 PM
  4. A4 18T Sport 51 Plate
    By Leigh A in forum Audi A4 - Archive Topics
    Last Post: 08-08-2007, 03:36 PM
  5. VW Polo 1.4 Sport '02 plate
    By trigger in forum Polo - Derby - Lupo - Fox
    Last Post: 13-01-2006, 07:05 PM
