Re: Audi A4 2.4 V6 2002 –
05-09-2008,10:33 AM
Originally Posted by
razer
hi all, I'm considering an Audi A4 2.4 V6 (petrol) saloon from 2002 - does this particular engine/model year have any common issues ? Does the standard equipment include the ISOFIX system for fixing child seats ? thanx !
A quick Google would suggest the following......
"All new car models introduced since early 2006 have been required by law to be fitted with 'Universal' ISOFIX anchorages for a minimum of two seating positions."
My 2002 model does not have ISOFIX.
I recall that there is an Audi technical document indicating that ISOFIX & LATCH anchors can be retrofitted - my source is the Bentley Manuals DVD for USA Audi cars.
Under Technical Bulletins I found document:
69-06-08 LATCH system, installing/retrofitting (DEC 18, 2006)
It lists all compatible Audi cars with part numbers for the kits from 1992 onwards.
A4 Saloon 1996-
TOP Tether Anchors:
- Anchor Bracket 443 887 269
- Cap: 443 887 301C (add colour code)
- Bolt: N 010 240 22
- Spacer: 810 019 829
- Threaded plate: 443 887 077C
- Rivet (qty 2): N 905 763 01
LOWER Anchors:
1999-2002
(probably B5 and before)
- ZAW 269 004 (R)
- ZAW 269 005 (L)
2002-
(probably means 8E/B6 models)
- ZAW 269 008 (R)
- ZAW 269 007 (L)
*** In view of the safety of your little ones I would check this out with a Dealer first ***
Reason: correct part no typo
A4 3.0 Quattro Sport Tiptronic (51) Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
Retrofits: S-Line Bumpers, Amb F&R LEDS, Xenon HID's (slimline) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Parrot CK3100 BT, RNS-E + Video i-pod + Aux inputs, Rear PDC, ISO-FIX, VCDS HEX+USB+CAN (VAG-COM)
