Thread: lowering my suspension A6 4.2 quattro
Results 1 to 10 of 18
  1. lowering my suspension A6 4.2 quattro
    Northumberland
    2000, A6, 4.2 quattro, and I would like some advice re lowering the big fella down a bit, say 30 mil, has rs arches and 235/35/19s on.
    thanks guys
  2. Re: lowering my suspension A6 4.2 quattro
    visage Guest
    How or where did you get the arches flared?
    Sorry I can't help with the lowering bit.
  3. Re: lowering my suspension A6 4.2 quattro
    Northumberland
    Came with the car, I was told by audi that they were rs arches, thats as far as i know, they are certainly bigger than a normal A6's
    I will post a pic to waynne if i can and he can put it up if thats o/k
  4. Re: lowering my suspension A6 4.2 quattro
    Northumberland
    [quote=Moesie;233562]Hi
  5. Re: lowering my suspension A6 4.2 quattro
    visage Guest
    Thanks for the quick response.
    Interesting that they were already on the car, I was just curious really because I have an S6 and the arches are aluminium of course, whereas I understand that the A6 V8 had steel ones.
    I'm selling my S6 as I need a diesel now but am still considering getting another A6 as I like the size, etc. It would be good to be able to flare the arches on one though because, as you know, it looks so much better.
  6. Re: lowering my suspension A6 4.2 quattro
    Northumberland
    If I knew how to i would send you a pic, but both front and rear arches are larger than normal .
    Got the lowering kinda sorted, gona go for bilstein B14's coilovers, ( £740 ) they seem to be able to do the job.
    Ride hight rear is now 65cm with 235/35/19's and i want it down to 61 ish.
    There aint much available for a 4.2 quattro
  7. Re: lowering my suspension A6 4.2 quattro
    visage Guest
    Sounds excellent, good luck with the Bilsteins, they're definitely the best from what I've heard.
  8. Re: lowering my suspension A6 4.2 quattro
    Northumberland
    Thanks 4 that m8
    Just scoped yours out on piston heads, it looks the real deal.
    My arches look the same as yours.
    Do me a favour come back with what size your 19" zero's are and if you could measure the arch to ground height front and rear
    thanks
    m
  9. Re: lowering my suspension A6 4.2 quattro
    visage Guest
    Quote Originally Posted by Moesie View Post
    Thanks 4 that m8
    thanks
    m
    Hi Moesie,
    The tyres are 255/35 ZR19 and I highly recommend these P- Zeroes over anything else.
    Front arch is 67.5cm (maybe 68 if the tyre had a bit more pressure in it)
    Rear arch is 69cm.
    Looks like someone's going to have an RS6 lookalike very soon!
    Cheers,
    Tony
  10. Re: lowering my suspension A6 4.2 quattro
    Northumberland
    i used to run 255/45/18's, but when i went up to 19's my tyre guy said that 255 would rub on the front, so i went with 235/35/19's, but i miss the look of the 255's from that back view.
    with a quattro its all down to those front tyres and what you can get away with, i will chase him up again re the 255's as i miss them so much.
    The new B14's when fitted might have some say with reguard to 255's.
    I will try and work out how to send you a picture of the laddo.
    thanks for your time and trouble Tony
    m
  1. Suspension Lowering in Scotland
    By macarthur.2000 in forum Golf MK4 - 1999 - 2004
    Last Post: 31-08-2008, 05:48 PM
  2. Question From A Newbie About Lowering My Suspension
    By ben.uk1 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-06-2008, 12:12 PM
  3. Knocking rear suspension after lowering
    By Bighands89 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-05-2008, 08:19 AM
  4. lowering suspension
    By audi90-2.3 in forum 80 - 90
    Last Post: 17-03-2008, 12:39 AM
  5. Lowering a Quattro?!?
    By bamjimpat in forum Archive posts
    Last Post: 12-04-2007, 01:11 PM
