Thread: 110BHP '99 Tdi trouble
Results 1 to 10 of 11
  1. 110BHP '99 Tdi trouble
    Having trouble with one of our cars at the moment. Its a '99 Bora with the 110BHP Tdi engine.
    The car runs fine, starting and cruising no problem but when the engine is under heavy loads, ie. accelerating to overtake or driving uphill the engine just loses power. Unable to maintain speed uphill and only just able to accelerate on the flat. It feels to me as if the turbo cuts out. The problem seems to occur at around the 3000rpm mark, the car accelerates quite well at that point with a real noticeable drop when this problem occurs. The strange thing is is that it does not always happen, seems to be more random, but only occuring under a heavy load. The other strange thing is that it clears itself by turning off the ignition and restarting the engine, which is not a pleasant experience on the motorway or a fast 'A' road.
    I dont really know too much about the workings of turbo diesel units but I am first inclined to think its a problem with pressure in the turbo? perhaps a wastegate not opening?
    Any techies out there have any clues?
    Thanks in advance.
    My car: VW Bora Sport '03 Tdi 150bhp
    Anyone in Berks/Bucks with that VAG com thingy ?
    Dec 2006
    Chelmsford, Essex
    Sounds like yet another Mass Air Flow sensor fault.
    Canada
    If you have a laptop you can buy a cable for £39.00 and download the freeware version of VAG-COM. well worth it as you can read the codes and VW Dealer will charge you at least this to do it.
    For cable look here http://www.gendan.co.uk/vag_diagnostics.php
    For deatils on VAG-COM look here www.ross-tech.com
    Rob
    Thanks.
    7 Post(s)
    I'm in Maidenhead with VAGCOM and might be able to help.
    The problem with MAF failures though is that they rarely produce any fault codes.
    I suppose theres no way of testing the MAF then?
    Forgot to add, that I was out and about this afternoon trying to reproduce the fault but could not trigger, high revs in all gears, accelerating uphill etc etc, nothing seemed to trigger it so it certainly is a random fault occasionally triggered in high revs or under load. From what I can remember the few times that it has happened have occured around the 3000rpm mark
    Canada
    when my MAF was gone it wouldn't rev over 3000, when i uppluged it it would rev over 3000 and was smoother. But still not full power. You can take reading from the MAF but you need vag-com and it still can be difficult. If it hasn't been chaged before it won't hurt and they do seem to have come down in price as they are well known for problems.
    Rob
    7 Post(s)
    I had to change mine on the Golf, about £80 exchange from the dealers and very easy to fit.
  1. 90bhp & 110BHP Passat TDi mileage - What are they good for?
    By SammyP in forum Passat - Archive Topics
    Last Post: 01-11-2007, 10:14 AM
  2. 90bhp to 110bhp
    By dan druff in forum Audi A4 - Archive Topics
    Last Post: 05-05-2007, 01:57 PM
  3. mk 4 golf tdi 2001 110bhp no power
    By dobski in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-02-2007, 11:24 PM
  4. 110bhp of roaring Tdi!!!!!
    By dieselfitter in forum New Member Introductions
    Last Post: 03-02-2007, 08:16 PM
  5. Audi A4 1996 TDI SE 110bhp problems
    By The Sandman in forum Archive posts
    Last Post: 29-07-2006, 07:06 PM
