Thread: Engine workshop! warning message
Results 1 to 10 of 10
Hybrid View
  1. Engine workshop! warning message
    While driving earlier today the coil light starting flashing followed by a warning message saying "engine workshop!"
    Car seems to be driving ok, can anyone shed some light on this??
  2. Re: Engine workshop! warning message
    Belgrade,Serbia
    you should have it scaned for codes but I suspect brake pedal switch. did it go off when you aplied the brake?
  3. Re: Engine workshop! warning message
    Oct 2006
    Check your brake bulbs - same thing happened on mine and made me jump!
  4. Re: Engine workshop! warning message
    Chester-le-Street, United Kingdom
    ditto
    first time i was up a ladder i was down a well
    4th cog,--two to go
  5. Re: Engine workshop! warning message
    Jun 2008
    Brake light switch, happened to me in july £6.95 for a new switch garage took 40 mins to change as the car was under warranty.
    If it ain't broke leave it alone!!!
  6. Re: Engine workshop! warning message
    Thanks for all the comments, however I would like to add that the brake lights still work while the warning message and coil light are flashing.
    Could this still be the brake switch? does it just mean the brake switch is on its way out.
    Or is it possible that the brake lights are failing intermittently, meaning I am coincidently checking the brake lights at the time they are working??
    Any assistance would be much appreciated.
  7. Re: Engine workshop! warning message
    I've also just realised that when the side lights or headlights are on, the brake llights are permanently staying on, regardless of whether my foot is on the pedal or not.
  8. Re: Engine workshop! warning message
    Jun 2006
    UK, Mids
    Quote Originally Posted by deezal View Post
    Could this still be the brake switch? does it just mean the brake switch is on its way out. .
    Yes, the brake switch has four pins, with normally open and normally closed contacts. The brake lights may well still work, but the switch can still be dud.
    Audi A8 - 2015 - 3.0TDI
  1. Oil Warning Light/message.
    By Giallo225 in forum Bora - 1998 - 2005
    Last Post: 08-02-2011, 05:28 PM
  2. 01 Passat TDi Engine Workshop! Message??
    By alba_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-02-2010, 03:04 PM
  3. Help "emissions Workshop" message TDI SE 1.9
    By ardasaliah in forum Golf MK5 - 2004 - 2009
    Last Post: 05-08-2009, 11:19 AM
  4. Warning- engine workshop.
    By ROBH in forum Passat - Archive Topics
    Last Post: 23-08-2007, 05:38 PM
  5. Alternator warning message
    By Chazzy in forum Passat - Archive Topics
    Last Post: 08-11-2006, 01:25 AM
