Thread: Engine Light
  1. Engine Light
    Aug 2008
    Don't know if this is in the right place, but I'm new!
    I have a 2001 B6 Audi A4 1.8T Saloon. When I turn on the ignition, the engine light no longer comes on. I have performed an output test on the instruments with Vagcom and it will light up for the test.
    Has it somehow been disabled? Can I reactivate it somewhere?
    I know the seatbelt warning light can be deactivated, so wondered if the other lights were the same.
    Cheers, Scott
  2. Re: Engine Light
    135 Post(s)
    2042 Post(s)
    Have you checked the coding value?
  3. Re: Engine Light
    Aug 2008
    Was hoping someone may be able to point me in the right direction!
  4. Re: Engine Light
    135 Post(s)
    2042 Post(s)
    That is what I was trying to do!
  5. Re: Engine Light
    Aug 2008
    OK - Would help if I knew which coding value to check. I've been all through 17 - Instruments, with no sign of anything that may be suspect.
    Is there anywhere else to try?
  6. Re: Engine Light
    135 Post(s)
    2042 Post(s)
    It is on the main screen and some versions of VAG-COM have pop up bubbles in Coding to help you. Some versions of the panel software allow the MIL to be turned off. I was wondering what the coding value was as that is how it is altered. Post a main screen grab.
  1. Engine Temp Light
    By rmtebbot in forum Early Passat Forum - Pre 97
    Last Post: 23-09-2008, 08:52 PM
  2. Engine Light On
    By ZivanF1 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-05-2008, 03:19 PM
  3. Engine maintance light + ABS
    By matt290 in forum A2
    Last Post: 04-02-2008, 01:30 PM
  4. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  5. engine management light
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-02-2007, 12:06 AM
