Thread: Odd noise when turning corners??
  1. Odd noise when turning corners??
    May 2008
    suffolk
    Hi all,
    Bit help if poss, not really sure how to describe this, but when i turn left into a corner my passat makes an odd noise, like maybe the springs are knackered/straining too much, however, they are new koni sports springs, bout 4 months they've been on car.
    When you push up and down on the boot aswell the springs don't sound great, sorry can't be any clearer, my shocks are good also.
    any ideas?? i know this is very vague
    carl
  2. Re: Odd noise when turning corners??
    Jun 2008
    When you changed the springs did you check out the other parts before you reassembled them.
    New and old parts dont normally like going together as the new parts will show any deficencies in the other parts.
    I fitted a lowered suspension kit to a 306 for a friend and for some time after there was some weird noises coming from the front. (Everything was replaced, bearings, rubbers etc)
    Double checked it but no faults were found but after a bit of hard use it all settled down and the noises disappeared.
    If its not a creaking groaning sound and more like a knocking noise then it could be the CV joints.
    If it ain't broke leave it alone!!!
  3. Re: Odd noise when turning corners??
    south wales
    i would say cv joints find a large carpark then try it full lock both ways also check the cv gators if there split
  1. Noise when turning key 1.6 SE golf w reg
    By ruby2005 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-07-2009, 04:26 PM
  2. knocking noise when turning
    By avantguard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-06-2008, 03:00 PM
  3. Clicking noise when turning
    By jonnocooper1987 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-05-2008, 04:35 PM
  4. clucking noise when turning the wheel
    By roadkill in forum Golf MK4 - 1999 - 2004
    Last Post: 23-02-2008, 11:38 PM
  5. Noise from turning lights on
    By andrew00011 in forum Audi A4 - Archive Topics
    Last Post: 24-01-2007, 02:14 PM
