Thread: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
Results 1 to 10 of 10
  1. Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    Sep 2008
    Hi all
    Do a VW transporter T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    And If yes is it placed in the tank or where ??
    Regards Ole
  2. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    134 Post(s)
    2014 Post(s)
    Yes, in the tank.
  3. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    Sep 2008
    Hi Crasher
    Thank you very much !
    Then I think that the problem I have is related to that pump.
    The problem is described here:
    It has always stated immediately, but within the last months, I first a couple of times observed that when I tried to start the engine it was just firing for a few turnings and then got out - just like it was able to run with that diesel which was in the pump but no new fuel got to the pump. Next time (after half a second) I tried to start no problem occurs.
    One time it was not able to start - engine just turning but no ignition. After a few attempts it’s started ok. - In the mean time I had to move the car a few meters - so I turned the starter while the var was in 1. gear - and in these way moving the car.
    For two weeks ago it wasn’t able to start at all. I tried a lot of time (more than 10 times in 3 hours). Then I changed the button switch in the ignition barrel, and after that it was starting OK. (But this time I also moved the car manually - and thereby shakes the car)
    The other day it wont start again, And now I have left it, and hope a friend of some of my friends will come with a diagnostic program so that we can read out errors codes.
    But in my opinion the problenm is the electric feeding pump.
    If you agree (or disagrre) please tell me
    Regards Ole
  4. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    Dec 2007
    Suffolk
    Get the fault codes read, possible fault with fuel pump relay or immobiliser
  5. Fixed with relay 109
    Sep 2008
    Hi Folks
    Tried to get the errorcodes read by a frind to a frind. He wasn't able to communicate with the engine part from the computer, bt okay with the other parts - eg ABS.
    But he mesioned just like smokey0123, that the most common fault would be "relay 109", which tae the fuel pump - and some more thinks i gues. Actually the realay smellled at bit burned.
    Todat i gor a new relay - actuelly a new type since the old was to weak - price aproximate 10€ and now it it running - and the best if i pun in the old relay again it aint working.
    So again a happy T4 ownwer
  6. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    Dec 2007
    Suffolk
    Pleased you got it sorted, them 109 relays are a common fault
  7. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    Jan 2016
    Stavanger
    Hey guys.
    Trying to hijack this 8 year old thread.
    I have a T4 2.5 TDI that only starts on starter spray.
    When I get it started with about 2 wifhs of starter spray, it runs and drives perfect with no engine / Warning lights.
    When turning the ignition on, the glow plug light is lid only for about 1sec !!!
    BUT, I measured the power to the the plugs and they are getting 12V power for about 5+ sec.
    Replaced all glow plugs.
    Replaced fuel filter.
    When I tried to prime the fuel filter, I found that there was no fuel coming from the feeder pump in the tank, when I turned the ignition on.
    Is it safe to assume that there is either something wrong with the power to the feeder pump or the feeder pump itself ???
    The pump should turn on when you turn the Ignition to "On", right ???
    As the car runs after using starter spray, its safe to say its not relay 109 ??
  8. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    134 Post(s)
    2014 Post(s)
    What are the results of a fault code read?
  9. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    Jan 2016
    Stavanger
    No engine / Warning lights when its running, so I did not perform a DTC read.
    What is the normal operation of the feeder pump? Does it turn on for a few secs when you turn the ignition on, like on a petrol regular car?
  10. Re: Do a T4 2.5 TDI have an electronic fuel pump to feed the injection pump ?
    134 Post(s)
    2014 Post(s)
    Just because the MIL does not illuminate does not mean that there are no codes stored plus using a suitable system you can see the data for coolant temperature and Commencement Of Injection timing.
    Which year and engine code is your T4, ACV, AJT, AUF, AHY, AXG, AYY or AYC?
    By ole in forum The Classic VW's
    Last Post: 11-09-2009, 09:04 AM
  2. injection pump
    By bhoy7 in forum Toledo
    Last Post: 27-03-2008, 10:20 AM
  3. Mk3 CL TDi: Direct Injection? Fuel Pump Type?
    By gavin44 in forum Golf MK3 - 1993 - 1999
    Last Post: 12-03-2008, 02:53 AM
  4. fuel injection pump timing T4 1.9 TD ABL
    By Volkner in forum The Commercial Range
    Last Post: 18-09-2007, 10:16 PM
  5. Injection Pump
    By grey in forum Chat - Anything with wheels
    Last Post: 26-05-2007, 06:58 PM
