Thread: lower my car?
Results 1 to 9 of 9
  1. lower my car?
    hi,
    i have a 2005 mk5 golf 1.6 fsi,i have modified the car in most areas and now im wondering should i lower the car 40mm all round? the golf drives brilliantly smooth and i dont want the ride to be rough and bumpy,does anybody know a good suspension kit or springs that would lower the car without comprmising ride comfort too much??
    40mm sounds a rather drastic drop, i suppose it depends also on what kind of size wheels your cars runing on, if you've got whopping great 19's you should probably have already lowered it, as the car will be on stilts, the handling will be poor to say the least.
    if you've got standard 15/16's on it, id probably go for a more tasteful 20mm drop, as for springs, try searching for a thread, im sure someone on here has had the same kind of thread before... other than that im sure one of the techies will be along to help soon ....
    Aug 2006
    Devon, UK
    I've lowered two golfs by 40mm, but not Mk5's. Though the handling was awesome on both, it was a little harsh. That was a long time ago, and I had trouble with speed bumps occasionally. These days I think 40mm is too much given the increasing frequency and size of speed bumps. You might find your front skirt crashing into them, and you certainly wouldn't want to smash your oil pan! You can get away with it, but you'll have to all but crawl over speed bumps.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
    Quote Originally Posted by Huweth View Post
    im not too sure you know, but i was under the impression the mk5 had a slightly lower natural ride height as it was, so 40mm on this could be even worse? i may be wrong though....
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    My fabia is lowered between 70-80mm all round, on adjustable coilovers. Makes for a bit of a stiff ride, but it gives good cornering performance and a good stance in general (I like the low slung look )
    Changing them for KW coilovers soon though. FK ones are a little cheap, but decent enough,
    Eibach springs are a good value way to get a 30-35mm drop.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Quote Originally Posted by eshrules View Post
    was talkin to a guy 2day with a mk5 golf he had dropped it 50mm on a set of rs8 19's! he swore it was still a comfy car 2 drive,anyways ive got a set of 18 inch highly polished monzas on the golf look crackin, as for handlin it is still pretty good the toyo proxes grip like f#*k!
    Quote Originally Posted by devonutopia View Post
    ur fabia looks lovely mate,wot kind of mods have u done to push 220bhp? wots the best car uv embarresed in the fabia? 70/80mm! must be sittin on its ****! is it still comfy to ride and would you lower a car that much again? ive seen the eibach springs £80 lowers it 30mm on springs for the mk5 you any idea bout ride comfort though?
    Barnes, London
    for the mk3...if i get a basic set of eibach springs, do i have to change the shocks? furthermore..how are insurance going to feel about it..
    Golf Mark III TDI 1996
    ¬ Upsolute Stage I
    May 2006
    Quote Originally Posted by Aaron Mac View Post
    Well, it's gone from
    to this
    Quite a drop, but then it was always high as standard anyway. No rubbing, even on full lock, and the look is great.
    Principle mods for power are: Hybrid turbo, FMIC, straight through exhaust "pipe", LPG injection and a Jabbasport remap. I'm not one to embarrass things, but I love surprising those who think they're rep mobiles are formula 1 cars. Once ruffled by one, I will damn well show them what it will do. Aside from that, I just give chavs a bit of a blast and drive fairly sedately everywhere else.
  1. Lower Door Runner
    By scoobystu in forum The Commercial Range
    Last Post: 18-07-2010, 10:24 PM
  2. Lower Suspension Arm Bush
    By lennymfo in forum Passat - Archive Topics
    Last Post: 17-01-2008, 07:49 PM
  3. Low Brake Pad Warning & Changing Lower Gear
    By dna_628 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-06-2007, 03:29 PM
  4. A6 front suspension lower arm removal
    By john493 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 04-11-2006, 06:50 PM
  5. Passat Lower Valence Spraying Problems
    By gerrymouse1 in forum Passat - Archive Topics
    Last Post: 19-07-2006, 03:13 PM
