Thread: sharan door panels
  1. sharan door panels
    Dec 2006
    hi can somone help, i want to know how do i take of the door panels on vw sharan
    thank you
  2. Thumbs up door trim
    Jul 2006
    scunthorpe
    unclip cover behind door pull lever using small screwdriver remove cross head screw then working from bottom of door unclip panel using a flat blade [if u havent got the correct tool ] do this carefully DO NOT FORCE PANEL when panel is unclipped from door release electrical connections the moisture sheet can be taken off & refixed up to 3 times without using additional sealants, hope this helps andy
    Dec 2006
    hi andy thank you for your reply i will try this and let you know how i get on
    Jan 2005
  5. Re: door trim
    Hi Andy
    I'h having difficulty at the first step ... I'm having difficulty unclipping the cover behind the door pull handle. Can you give more detail on how to do this please.
  6. Re: door trim
    May 2008
    wirral
    Quote Originally Posted by govanit View Post
    Hi Andy
    just prize it of its not screwed in when prize of you will then see 3 i think 13mm bolts take out then follow the rest as instructed above.you wont break it...
  7. Re: sharan door panels
    Portugal
    Hello.
    I've recently also have to dismantle a front door panel of my 2001 Sharan, and i've found this great forum the explains, with pictures, a lot of procedures. It's in german, but with google translate its readable.
    http://74.125.93.104/translate_c?hl=...6dZOreqs-XYNmw
    Hope that it helps.
    Good work.
  1. Sharan door rattle
    By Timothy in forum Touran - Sharan - Caravelle
    Last Post: 14-08-2011, 09:23 PM
  2. Knocking in side door/ door panel removal
    By AudiwantisanS3 in forum Audi A3 - Archive Topics
    Last Post: 04-03-2008, 06:06 PM
  3. VW Sharan
    By mike in forum Touran - Sharan - Caravelle
    Last Post: 14-12-2007, 10:12 AM
  4. Remove Door Panels
    By starhannes in forum Archive posts
    Last Post: 22-02-2007, 06:12 PM
  5. VW Sharan Sat Nav
    By efiokcas in forum Touran - Sharan - Caravelle
    Last Post: 15-03-2006, 10:01 PM
