Thread: Brake Trouble
  1. Brake Trouble
    Sep 2007
    I have a 2001 A4 1.9TDI. The problem I have is if I apply the foot brake rapidly the pedal will fall to the floor. The brakes seem to operate OK under normal conditions. The brakes pump hard with ignition off, but if I start the engine whilst applying the brake the pedal falls. Hope I have given enough info for someone to give me some pointers. Thanks in advance
  2. Re: Brake Trouble
    132 Post(s)
    1980 Post(s)
    Has anything been done to it recently? Have you had a problem with water ingress into the car or the plenum chamber around the battery filling up with water?
  3. Re: Brake Trouble
    Sep 2007
    I had a new rear caliper about 3000 miles 1 months ago. This was done at the same time as a service was carried out. No sign of water ingress though
  4. Re: Brake Trouble
    A, A
    Search Master and Slave brake cylinder
    Welcome to the forum
    Just another B7 Estate
  5. Re: Brake Trouble
    Sep 2007
    Thanks for replies. Found the "new" rear brake caliper was leaking from the piston So getting it sorted for nowt
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. Please Help brake lights allways on / brake relay location
    By rswspeed1 in forum Alhambra
    Last Post: 22-06-2008, 07:24 PM
  3. having trouble
    By ross523 in forum Archive posts
    Last Post: 06-01-2008, 11:47 PM
  4. brake lights / brake switch recurring nightmare!
    By stuart40 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:23 PM
  5. Brake pipe trouble
    By welsby76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2007, 11:14 AM
