Thread: air con compressor
  1. air con compressor
    Jan 2008
    hi the air con compressor on my vw sharan 1.8 turbo has packed up , does any body know if the same compressor from any other VAG 1.8 turbo model will fit ?, or even the 1.9 tdi models
    eddie
  2. Re: air con compressor
    london/ UK
    You need to find out wich one you have as they fitted 2 types: 1 made by Nippon Denso-(ussualy early cars) and the other by Zexel. The make is printed on a label on the compressor. Once you have the make, scour the ebay for a new or recconditioned one with warranty. Do not go for second hand ones as the alloy fittings will be corroded and snap. As the system is under pressure, a leak is not reccomended. Also, breakers charge big bucks for them and chances are that you will loose your money.
  3. Re: air con compressor
    Jan 2008
    hi thanks for that , i'll check it out over the weekend, seen some used one on ebay but there off audi a3's or golfs
    thanks eddie
  1. air con compressor number
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 18-08-2008, 02:21 PM
  2. Question A/C Air Compressor - Options
    By Chris_J in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2008, 08:30 PM
  3. Question A/C compressor replacement
    By jb1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-06-2008, 10:37 PM
  4. Air con compressor
    By slickoneuk in forum Archive posts
    Last Post: 15-10-2007, 05:08 AM
  5. Which model air compressor?
    By Hillfly in forum Passat - Archive Topics
    Last Post: 03-06-2007, 04:47 PM
