Thread: Hard to start Engine in the morning everyday
  1. Hard to start Engine in the morning everyday
    hello ,
    as the subject. Any idea about what's wrong with my Bora 2.0 Y2000? Should I try to clean my engine using some product like gas and diesel treatment ?
    Sincerely,
    Laurence
    Oct 2005
    Lutterworth
    Change the coolant temperature sensor.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  3. Talking
    Quote Originally Posted by Lex Luthor View Post
    how can you possibly come up with that diagnosis, you dont even know what car it is, what mileage on the engine, whether its stored in a warm garage or anything? .....
    to the OP ... can we have a little more detail as to whats actually happening? also, if you could update your signature to include your car details that would be brilliant
    Oct 2005
    Lutterworth
    Quote Originally Posted by eshrules View Post
    Well if you read the post it is a Y2K Bora 2.0 petrol.
    OP does not say it is running badly, just that it is hard to start.
    Logically therefore the CTS may have failed and the mixture is not rich enough for a cold start.
    The CTS is a very cheap part and is an easy DIY change, so I feel my suggestion is perfectly reasonable.
    Passat 1.8SE 1998
    Jun 2006
    Droitwich, Worcestershire
    Ive had the coolant temp sensor brought up on a post i started last week. My Bora (2000 1.9TDi) is hard to start when its hot though. I must admit i was suprised this could be the cause of the prob but will have a go at changing it if the prob gets considerably worse.
    Quote Originally Posted by Laurence Tsai View Post
    hello ,
    Sincerely,
    Laurence
    Go for a free battery check at quickfit to confirm it's not low electrics causing your problem or faulty altenator and how about your service details,how old is your oil&filter/airfilter/petrol filter/sparkplugs and the condition of your rotor&distributor cap and ht lead's(if applicable) For a 2000 bora your fuel should be fine and some treatment products can destroy your catalytic convertor(lot's of money£££££££££££)
  1. Engine Fans Start Up after Engine is Switched off??
    By batman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2009, 02:15 PM
  2. 1999 VW Cold Start Engine Problem
    By cmarkopoulos in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-04-2007, 10:11 AM
  3. Does your oil light go out before engine start?
    By Alas in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2007, 10:04 PM
  4. Seem's I have a new problem just about everyday
    By darren74 in forum Passat - Archive Topics
    Last Post: 21-02-2007, 09:11 AM
  5. Hard to start
    By crafty in forum Passat - Archive Topics
    Last Post: 29-11-2006, 05:53 PM
