Thread: Audi A3 2.0 fsi 2004 coolant sensor
Results 1 to 8 of 8
  1. Audi A3 2.0 fsi 2004 coolant sensor
    May 2008
    Hello all!
    Can anyone tell me the exact location of the engine coolant temperature sender on an A3 2.0 fsi 2004 (engine code axw)
    I have had a good look around the engine but can't seem to find the one i need to replace.
  2. Re: Audi A3 2.0 fsi 2004 coolant sensor
    Aug 2008
    north hampshire
    in ur engine coolant tank the should be a sensor in there! i would have thought it would be that!
  3. Re: Audi A3 2.0 fsi 2004 coolant sensor
    Hi the temp sensor is on the plastic housing on the end of the cyl-head
  4. Re: Audi A3 2.0 fsi 2004 coolant sensor
    May 2008
    Quote Originally Posted by kenney View Post
    Hi,what side of the cylinder head is it on if i am standing at the front of the car?.
    I have posted a picture of the coolant sensor i need to install.
  5. Re: Audi A3 2.0 fsi 2004 coolant sensor
    The end above the gearbox
  6. Re: Audi A3 2.0 fsi 2004 coolant sensor
    Sep 2008
    Is it not the sensor that I have circled in red? (on the attachment)
  7. Re: Audi A3 2.0 fsi 2004 coolant sensor
    Quote Originally Posted by whitegoosedown View Post
    No, that is the coolant shortage indicator switch
  8. Re: Audi A3 2.0 fsi 2004 coolant sensor
    May 2008
    Many thanks for that!
    Finally got a chance to replace the sensor this morning in between the showers.
    Standing in front of the engine,the coolant sensor is on the right hand side of the cylinder head.It is much easier to see if the battery and its case are removed.
    It was tricky to actually get my hand on it,but easy to remove.I tied a piece of string around the plastic clip that holds the sensor in place so i couldn't drop it.
    Lost a little bit of coolant when i pulled out the old sensor,no more than half a pint though.
    Just had the car out for a drive and everything is fine now,the engine management light has gone and the temp gauge works nice and smoothly.
    The black arrow in the picture points to the sensor.
  1. T5 Transporter Tdi 130 2004 Coolant loss
    By Golfer7 in forum The Commercial Range
    Last Post: 31-08-2008, 08:24 PM
  2. Please Help Location of Coolant Sensor - 2004 1.9 TDI 130
    By redhotorange in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2008, 10:39 PM
  3. Iat Sensor On 1.9tdi 2004 Golf Mk5
    By bigshorts1 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2008, 11:16 PM
  4. 2004 A6 1.9TDi Engine Coolant Temperature Sensor
    By tiptop in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-05-2008, 02:39 PM
  5. A3 2004 2.0L FSI Low coolant warning light
    By dumpee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-04-2008, 01:09 PM
