Thread: Electrical problems with boot lid and Roof container lid
  1. Electrical problems with boot lid and Roof container lid
    Blackpool, Lancs, UK
    Having just purchased my first Audi 2.0e Cabriolet 1994, I find that the central locking actuator for the boot lid has stopped working, now when i lock the doors with a key everything locks apart from the bood lid and the horn doesn't do its usual single beep, I also tried to open the roof (its manual) when i pressed the button to release the roof compartment lid the light on the dash flashed but the compartment lid stayed shut. I know I need to replace the central locking actuator in the boot, does anyone have any idea how much this is going to be? and is this faulty central locking actuator the reason why the roof compartment lid won't open? Any advice gladly received.
    Thanks in advance
    I think i may have found the answer to my problem in this post
    https://www.vwaudiforum.co.uk/forum//...ead.php?t=3605, however I will have to let you know once i have located an actuator and fitted it to see if this cures the problem with my roof compartment and central locking.
    Comments and and advice are still gladly recieved from anyone who has had this problem on my specific car 1994 Cabrio 2.0e ( I am not sure if this is classed as an A4 or an 80 doesn't say on the V5 just Cabriolet, would be helpful to know for getting service manuals and parts etc.)
    Thanks Again
    Last edited by cabri-ole; 28-01-2007 at 12:50 PM. Reason: Spotted similar problem in another post but different model of car
  2. hood compartment button
    had this problem myself last year. might be the same as yours check your lights at the rear mainly mumber plate light and reverse lights are working. reason is down the left hand side of boot lid hinge runs a thin wiring loom.the age of your car or over years of opening and shuting the boot lid,breaks the wires down in this loom it is covered with a plastic sheaf.open it up and you should find one or 2 wires broken. you should be able to splice some new wire in hope this helps. ROB
  1. Electrical problems, no brake lights
    By wookiee_rob in forum Scirocco - Corrado
    Last Post: 27-03-2008, 11:21 PM
  2. Passat electrical problems!!!
    By tezmos in forum Passat - Archive Topics
    Last Post: 06-02-2008, 08:03 PM
  3. A4 B7 boot spoiler and roof fin
    By jum1000k in forum Audi A4 - Archive Topics
    Last Post: 31-07-2007, 09:32 AM
  4. electrical problems Golf Mk 4 TDi 130
    By Maurice in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-01-2007, 03:46 PM
  5. Major Electrical Problems!!
    By kriskros in forum Passat - Archive Topics
    Last Post: 15-12-2006, 09:19 PM
