Thread: Mud Benind Front Wings - Water Trap
  1. Mud Benind Front Wings - Water Trap
    Dec 2007
    New Mills, Derbyshire
    I just thought Id mention a job that is well worth doing, takes about an hour
    Mud and silt etc builds up behind the plastic splash panels at the rear of the front wings (Behind where the mudflaps fit) This mud and silt etc holds water and could well in time cause corrosion problems Its easy to get rid of, just remove the front wheels to gain easy access to the five hex screws that require removing, the rear of the splash panel will then easily pull away enough to dig out the mud and rinse with a hose It was a good 5 inches deep both sides on my Golf!
    The weight saving and increased fuel economy alone makes it a job worth doing!!
    Now all I need to do is the the full stop button etc on my keyboard working!
    150 GTI DIESEL - propper juice!!
  2. Re: Mud Benind Front Wings - Water Trap
    Southampton, UK.
    Thanks for the top tip!
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 2.0 TDI ultra 190
  3. Re: Mud Benind Front Wings - Water Trap
    Bath, Somerset
    Will do this on mine I think. The mudflaps were fitted from new so god knows how much dirt is trapped behind. Will post up what I find
  4. Re: Mud Benind Front Wings - Water Trap
    Dec 2007
    Quote Originally Posted by dubcruiser View Post
    Yep, remove the mudflaps (Held on with two hex screws, though I used stainless steel ones and penny washers in mine), there are then a futher two or three to remove in order to pull the plastic splash panel away enough to get to the mud etc! I rekon you will find it around 5 inches deep!
  5. Re: Mud Benind Front Wings - Water Trap
    A friend of mine did this. He had grass growing in it and allsorts
  1. Water trap on saloon
    By Perry in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2010, 09:01 PM
  2. Water in Front Passanger Footwell
    By triumphman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-05-2008, 03:54 PM
  3. water leak from front left
    By eddieace in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2008, 10:23 PM
  4. Never fall into the trap....
    By Clinterous in forum Chat - Completely Off Topic
    Last Post: 15-02-2008, 04:07 PM
  5. water coming from the front wheel arch
    By nerrad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 11:13 PM
