Thread: Help! Key Stuck in Ignition
Results 1 to 9 of 9
  1. Thumbs down Help! Key Stuck in Ignition
    Aug 2008
    Hello, my first post on this forum & it’s not for a good reason.
    The key is stuck in my ignition in my ’52 Passat!
    I can turn it, but when I try to pull it out it won’t come out. If I try to start the engine the key sort of clicks & locks in to position – the engine won’t start.
    If I press the buttons on the key fob it doesn’t lock/unlock.
    Any ideas on a quick-fix, or is it fubared?
    John
  2. Re: Help! Key Stuck in Ignition
    Bradford
    Is your steering lock on? This once happend to my dads honda, we ended up spraying some wd40 down the ignition barrel giving the key a twist and it finally came out
  3. Re: Help! Key Stuck in Ignition
    Nov 2006
    Good idea!
    I had a slightly different problem on my BMW 520 where the key would go in and out of the barrel but wouldn't turn. It was dropped tumblers in the barrel and required the car to be recovered and a new barrel fitted. I went to BMW because I didn't want to end up with different keys for ignition and doors etc.
    Apparently dropped tumblers are not uncommon especially on higher mileage cars.
    I hope the WD40 works - good luck!
  4. Re: Help! Key Stuck in Ignition
    Aug 2008
    LMAO.
    OK – I suck at autos! Just walked back to my car to try to force the steering wheel, in case it had something to do with the steering lock. Open the door & the first thing that I notice is that the gear lever is in the middle of the ‘box – in drive! Slide it into park….the key slips out.
    It must have slipped my mind when I parked up. I’ve not had the car long & it’s my first auto – it’s not quite second nature yet.
    Thanks for the speedy replies, though. Feel like such an idiot now.
  5. Re: Help! Key Stuck in Ignition
    Dec 2006
    Manchester
    Quote Originally Posted by W8_JP View Post
    LMAO.
    lol, Lesson learnt.
    Welcome to the forum!
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  6. Re: Help! Key Stuck in Ignition
    Nov 2006
    LMAO.
    I've never had an auto before and didn't know they did that. Do all autos do that?
  7. Re: Help! Key Stuck in Ignition
    Dec 2006
    Manchester
    Quote Originally Posted by chrisball666 View Post
    Well you learn something new everyday
    Yeah, modern (automatic) cars need to be in "park" to remove the key.
    1.9 tdi PD 100 Bora
  8. Re: Help! Key Stuck in Ignition
    May 2008
    iv did that before
  9. Re: Help! Key Stuck in Ignition
    Dec 2007
    crawley, west sussex
    Haha, that happened to my missis when we got our car, she put in park but the chrome button on the gear lever didn't come out, it took us ages to work it out, a bit of wd40 & it's been fine ever since
  1. Key stuck in ignition
    By JayCeeOhh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2017, 09:32 PM
  2. VR6 stuck?
    By Sears in forum Golf MK3 - 1993 - 1999
    Last Post: 22-07-2008, 04:23 PM
  3. Sat Nav stuck- pleeeeease help
    By thecount in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-05-2008, 12:17 PM
  4. help! i'm stuck in my car!
    By dazza01 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2008, 07:22 PM
  5. CD Stuck!!!!
    By Scottmully82 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-02-2008, 09:14 PM
