Thread: What IS The Green Cap ?
Results 1 to 9 of 9
  1. What IS The Green Cap ?
    Hi everyone...
    Slightly bizarre question to ask for my first one but....
    Just checking the oil/water etc under the bonnet of my 2005 Passat Estate 103 TDi when I noticed, on the right hand side of the engine bay in front of the windscreen washer bottle there is a green screw cap. On removing it there was a small dip stick attached to teh cap and a black, oil type fluid inside.
    Can't find any pictures or references to what this is in the VW hanbooks and I've read the thing from back to front. No sign or mention of it in any of the engine bay pictures either...what is it ?
    Feb 2004
    Yorkshire
    49 Post(s)
    Sounds like the power steering resovoir.
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    I'd say its the PAS as well. My pump/reservoir sits right by the washer bottle too.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    Thanks guys. That was my suspicion as well but it was odd that its not mentioned in the "Tips and Maintence " section. Its down to minimum but no mention of the type of fluid required to top up so can I assume a generic PAS fluid will do or does it use engine oil ?
    Feb 2004
    Yorkshire
    49 Post(s)
    Do not use ordinary PS oil or engine oil for this! you will cause a lot of damage if the incorrect oil is used
    If it has a "GREEN" cap, I belive it is hydraulic mineral oil that is used, VAG part number G002000. If you speak to a VAG specilist or dealer they can advise you about this.
    It may even show the number on the resovoir.
    Stuart
    Thanks Stuart.
    The res has a plastic "cover" around it but I'll check in the morning. VW obviously don't consider it to be a "DIY" top up...which is weird as they trust us with brake fluid....
    Nov 2006
    derbyshire
    ATF oil is just as good as mineral hydrulic oil.
    Feb 2004
    Yorkshire
    49 Post(s)
    Having worked at a dealer for 14 years I have seen the results of putting ATF in a car system designed for hydraulic oil.... for a start the hydraulic oil is just a little thicker than water....
    Almost every car we had in the workshop had to have either the pump OR rack replaced if not both. It attacks the seals.
    If you want to use ATF or any other oil, other than the correct grade/specification be prepared for the expence
    Appreciate the tip gresty but I would be mixing ...not a good idea I thnk.
    I'll pop into my local VW dealer tomorrow
  1. oak green valve
    By dollars in forum New Member Introductions
    Last Post: 17-05-2007, 06:48 AM
  2. Green Tax???
    By rnr81 in forum Audi A4 - Archive Topics
    Last Post: 22-03-2007, 08:43 PM
  3. yellow and green connectors on cd lead?
    By jenno69 in forum Passat - Archive Topics
    Last Post: 13-08-2006, 11:00 PM
