Thread: CD problem & Replacing Gamma radio on Passat
  1. CD problem & Replacing Gamma radio on Passat
    Aug 2008
    Stockton-on-Tees
    Hi, I have had a 02 Passat TDi estate for about 6mnths, and the CD player has a fault. I get the error message 'Chk MAGAZINE' each time I insert a CD, which is then ejected. There is not a CD changer fitted. I have tried a lens cleaner to no avail. Any Ideas?? The 'Gamma' radio works fine.
    I have a nearly new 'Tevion' CD, MP3, radio, which I used in my Peugeot 306 for about a month before I acqured the Passat, and was quite impressed by it. Does anyone know if replacing the 'Gamma' radio unit with the 'Tevion' unit would be straight forward, or are there problems, such as the 'speed volume control' to overcome.
    Thanks in advance, Bob E.
  2. Re: CD problem & Replacing Gamma radio on Passat
    NE England
    Quote Originally Posted by bobeasby1 View Post
    I have a perfect working gamma unit you can have for £10 just has a little corner button missing (I might even manage to find it). No longer have my passat so no need for it. Will be down stockton in next couple of weeks if you want it delivered free.
  3. Re: CD problem & Replacing Gamma radio on Passat
    Should be able to replace the stereo like for like if it has standard ISO plugs on the back, you may lose certain features the speed controlled volume been one of them and also possibly the dimming illumination with headlights.
  4. Re: CD problem & Replacing Gamma radio on Passat
    Aug 2008
    Stockton-on-Tees
    Quote Originally Posted by steadsy View Post
    Hi, Sorry for late reply, your message came through whilst I was on holiday. Do you mean you have a Gamma CD unit or radio (or both), as it is the CD player I am having problems with?
  5. Re: CD problem & Replacing Gamma radio on Passat
    Aug 2008
    Stockton-on-Tees
    Quote Originally Posted by monzablue16v View Post
    Thanks for advice, I could live with that. I can only give it a try. Cheers.
  6. Re: CD problem & Replacing Gamma radio on Passat
    NE England
    sorry...misunderstood the problem, it's the head unit I have not the cd changer. good luck. Steadsy
  7. Re: CD problem & Replacing Gamma radio on Passat
    Aug 2008
    Stockton-on-Tees
    Thanks anyway. Cheers, Bob E
  8. Re: CD problem & Replacing Gamma radio on Passat
    Apr 2009
    rochdale
    hi there, did you manage to find out the probkem with this, only we have just bought a mk 4 golf and we get the message CHK MAGAZINE? it wont play an cd's at all but radio is fine? any help would be much appreciated...
  9. Re: CD problem & Replacing Gamma radio on Passat
    Aug 2008
    Stockton-on-Tees
    Hi, Mine started working Ok after a period of not being used. It has occasionally played up again, but it seems to be with certain cds, and starts working ok again after a day or two. I will get round to putting the other unit in that I have at some stage. Sorry I can't help more, Cheers, Bob E
  1. gamma radio help
    By carl_v64motion in forum Golf MK4 - 1999 - 2004
    Last Post: 02-03-2008, 11:02 PM
  2. Gamma Radio Problem :-(
    By Christian82 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-01-2008, 01:42 PM
  3. Gamma Radio problem
    By passat owner in forum Passat - Archive Topics
    Last Post: 12-09-2007, 01:25 PM
  4. S Reg Passat Gamma Radio problems
    By AndyGlos in forum Passat - Archive Topics
    Last Post: 27-03-2007, 11:39 PM
  5. 98 Passat Radio CD CCM problem?
    By limawhiskey in forum Passat - Archive Topics
    Last Post: 14-10-2006, 11:18 PM
