Thread: after market stereo problem
  1. Angry after market stereo problem
    Aug 2008
    Bedfordshire
    iv noticed when changing vw standard head units to after market ones i cant seem to save function eg. when engine is turned off and key taken out i lose all imformation and the head unit restarts as if new, can anyone help? happen on my mk3 golf and passat b5? iv bought proper iso plugs but still no joy, iv never had a problem with previous cars its just the vw's!
  2. Re: after market stereo problem
    May 2007
    hi i had this problem had to get my local spark to change some wiring did not cost much
  3. Re: after market stereo problem
    7 Post(s)
    Quote Originally Posted by 786sam View Post
    The permanent and ignition switched live cables are reversed to normal ISO wiring on VW's.
    What you need to do is simply change over these cables (usually yellow & red respectively) to enable your stereo to function correctly.
    Some adaptor looms will have the facility to un-plug and plug these cables to reverse them.
  4. Re: after market stereo problem
    Aug 2008
    Bedfordshire
    so basically i just connect the yellow to red and red to yellow?
  5. Re: after market stereo problem
    7 Post(s)
    Thats it, yes.
  6. Re: after market stereo problem
    Aug 2008
    Bedfordshire
    thanx guys its worked!!!! 2 second job! thank you
  1. Problem with concert stereo
    By bonerp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2008, 02:58 PM
  2. Question stereo problem
    By Andrew Hird in forum New Member Introductions
    Last Post: 29-06-2008, 11:28 AM
  3. After market stereo and can bus
    By PNS2007 in forum VCDS - General Questions
    Last Post: 12-05-2008, 07:26 PM
  4. Problem fitting new Stereo
    By ahmet in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-04-2007, 11:06 PM
  5. A6 Stereo problem/question. please help!!!
    By djneils98 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-03-2007, 01:22 PM
