Thread: ABK engine pinking / pre-ignition
  1. ABK engine pinking / pre-ignition
    Aug 2008
    Coleford, Glos, UK
    My 1992 80 2.0E pinks when hot and under load, e.g. accelerating or climbing a hill. It has the ABK engine, auto gearbox, less than 89000 miles, recently serviced, no fault codes found after thorough check.
    Can anyone suggest a reason please ?
    Keith
  2. Re: ABK engine pinking / pre-ignition
    Gwent
    pinking could usually be down to overadvanced ignition timing, too high compression ratio (skimmed head?) or low octane fuel.
    I guess the knock sensor could also be faulty, but if so it should have shown up on the code read?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: ABK engine pinking / pre-ignition
    Gloucestershire
    If anything like mine you need to get the dizzy timing adjusted, strobe light on the dizzy markings, as stated sounds too advanced to me.
    Nothing drastic just need to find a good spanner man with the brains and the light!!!!
    Audi A3 1.8 20v 1998
    Audi A6 2.5 TDi 1996
  4. Re: ABK engine pinking / pre-ignition
    Aug 2008
    Coleford, Glos, UK
    Thanks very much Scotty and SDK (is the pic of you ?!!)
    My good spannerman says he can't retard the timing without reducing performance. The head has been off (cambelt tensioner self-destructed, pistons clouted valves) but don't know if it was skimmed - I'll try to find out. Thanks for that thought. I can't remember if it pinked before that episode.
    The pinking doesn't seem to be fuel-related, and I tried a different knock sensor without success. I'm hoping someone is going to say 'ah, yes, it's usually the blodging widget on the ABK engine' but perhaps I'm too hopeful :-).
    Keith
  5. Re: ABK engine pinking / pre-ignition
    Gloucestershire
    Quote Originally Posted by audi80mk4 View Post
    Keith
    No, that's the wife ( I wish)
    Mine lost a teeny weeny bit of performance when it was retarded, you hardly notice the difference, fuel economy jumps up too, so a few penny's saved there, all i can suggest is get him to drop it back a few deg and try it, i had the same with mine, he would play with it, i would drive it, then he would play again and so on.
    Try a higher octane fuel, optimax or BP ultimate etc.., may be woth a go.
  6. Re: ABK engine pinking / pre-ignition
    Gwent
    If the head was skimmed or the piston crowns are coked up, the compression is higher than oe spec, either higher octane fuel is required or timing needs to be retarded to suit. Yes there would be a small hit in performance but better than a set of damaged pistons/bores?
    The only 'widget' I can suggest checking is the infamous Relay 30 which seems to cause a variety of ABK problems, but I have not heard of it causing pinking...
    I posted the location and photo's in this thread if you care to check it?:
    https://www.vwaudiforum.co.uk/forum/s...?t=2946&page=8
  7. Re: ABK engine pinking / pre-ignition
    Aug 2008
    Coleford, Glos, UK
    Hi chaps, thanks for all your input and info
    Optimax may have helped a bit when I tried it some time ago, but look at the price now ! Don't want damaged pistons etc, although another spannerman (a VAG-trained friend who ran a 200 turbo engine in a coupe quattro - it pinked like hell at first) says there's not much risk of that. Spannerman says the head would have been skimmed very lightly as it wasn't overheated, and the skim was compensated for by a thicker head gasket. My pistons are never coked up
    First I think I'll try this, posted by marki in the thread to which scotty referred : "I needed to change the cambelt.Mine has 140,000 on 2.6 V6. The night before I disconnected the battery to reset the ECU.( i think it takes 10 hrs to reset) This is a common method used by the Japs. The ECU can 'drift' as the engine wears and parts are changed. ....It then relearnt itself. Now, in the morning before I took it to the garage I did notice smoother running !"
    If that doesn't do it I'll retard the sparks, and after that I'll hunt down the villainous Relay 30 and check it. The plugs fitted are NGK BUR6ET, one grade colder than recommended - anyone know if NGK are a no-no for the ABK engine ?
    I've been trying to think of some pearl of wisdom I can offer, this being my first thread an' all, but I fear such gem will have to be the solution to this one !
    Many thanks again.
  1. ignition light on engine wont turn over
    By wendyjane in forum Touran - Sharan - Caravelle
    Last Post: 10-09-2009, 09:27 PM
  2. Possible Pinking ???
    By mwshy in forum Golf MK4 - 1999 - 2004
    Last Post: 05-07-2008, 07:05 PM
  3. pinking golf 3
    By paul targett in forum Chat - Anything with wheels
    Last Post: 04-07-2008, 06:16 PM
  4. 3.2 Engine Pinking
    By Hillsy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-04-2008, 09:27 AM
  5. Pinking 1.8 mpi golf?
    By summers in forum Golf MK3 - 1993 - 1999
    Last Post: 14-12-2007, 05:49 PM
