Thread: ipod confusion audi models
Results 341 to 350 of 356
Threaded View
  1. ipod confusion audi models
    May 2007
    knee deep in clunge
    14 Post(s)
    Hello all,
    i have noticed there are lots of questions about ipod integration for Audi models so I will offer some advice on what you can retro fit at this present time.
    Q7 mmi high
    Here's the retro fit kit for ami 4L0 055 307 A
    contents
    4L0 055 307 A MEDIA WIRING HARNESS
    WSK 014 720 INSTALLATION INSTRUCTIONS
    4L0 864 515 A 6PS COVER
    4L0 864 981 E 6PS MEDIA COMPARTMENT
    4L0 898 283 SPRING SET
    WHT 001 250 A PLASTIC PINS
    N 906 986 06 TORX SCREWS FOR MEDIA HOUSING
    4L0 863 269 4PK PROTECTIVE PIECE
    N909 187 01 TORX SCREWS FOR PROTECTIVE PIECE
    4E0 057 785 XX THIS IS THE AMI CONTROL UNIT WHICH YOU NEED TO DOUBLE CHECK FOR THE LATEST HARDWARE/SOFTWARE VERSION PART NUMBER.
    OK YOU NEED TO CHECK YOUR MMI SOFTWARE VERSION BECAUSE IT NEEDS TO BE RUNNING AT 3460 AND ABOVE SO I WOULD ADVISE YOU UPDATE TO THE LATEST RELEASE UPDATE 4L0 998 961
    Code the gateway for media position 2 and clear all your fault codes and test.
    The ami fits beneath the arm rest and your just bridging the diagnostic wires and most cables at the multi changer which the pre made loom fits lovely.Also you will need your ami lead for the ipod connection
    B8 A4 AND A5
    These models with mmi high or the operator controls around the gearstick/centre console can support ami and dension 500
    AMI CONTROL UNIT 4E0 057 785 B,D OR F
    HOUSING 4E0 060 700
    COVER CAP 4E0 060 701
    SPRINGS 4E0 060 702
    DRAW 4E0 060 703
    WIRING LOOM 4F0 051 592 A
    B8 A4 AND A5 GENERATION 3 RADIO WITH AUX INPUT SOCKET
    These models can support ami can bus and ipod interface buid week 22/08
    WIRING LOOM 8K0 051 592
    AMI KIT 8T0 057 785
    Also a new glove box is required
    A3,TT,A4 UP TO B7 ,A2,A6 UP TO 2005 concert,chorus and symphony 2,rnsd ipod kit interface 20 pin kit single din 8E0051444A
    From 2005 double din units chorus,concert and symphony +,rnse and bns 5 supports ipod interface 12 pin double din 8E0051444B
    A8 mmi high
    Supports ami and dension 500
    HOUSING 4E0 060 700
    SPRINGS 4E0 060 702
    DRAW 4E0 060 703
    AMI FITS IN THE GLOVE BOX FOR A8
    A6 mmi high
    Build week 22/07 pr number 7d3,8yq up to build week 44/07 ami kit 4E0 057 786B includes fitting instructions
    Build week 45/07 till build week 21/08 ami kit 4E0 057 785D includes fitting instructions
    WIRING HARNESS 4F0 051 592A fits both units control units
    A6 and Q7 mmi Basic Plus (RED SCREEN)
    Supports Dension 500
    2010 RNSE UNITS FOR R8,TT,A3
    AMI can be retro fitted
    wiring harness kit 8K0 051 592
    AMI unit 8T0 035 785
    NOW ADDED MMI 3G AMI ACTIVATION
    ami lead part number 4f0 035 909 (just check to make sure the securing clip comes with the lead to locate the dock in the glove box)
    this lead plugs direct into the 5f control unit so no need to splice wires etc
    the glove box has a pre cut position so you can remove the glove box find the pre cut and push the insert out and locate the ami ipod dock
    then plug the ami lead into the ami and refit the glove box
    now you need to access the hidden menu in address 5f
    select address 5f
    select adaption 10 channel 6 and set the value to 1 and save
    now reboot the mmi using the softkeys
    when the mmi comes back on press and hold set up and car until the green menu comes on
    scroll down find diagnosis and enter then select settings and then scroll down to ami set this to 7/8
    come out of the green screen and reboot mmi
    now test the ami
    total cost around £170 + vat
    Update
    Ami retro fit kit official audi p/n 4G0051960 for mmi 3g also if the dealer does the retro fit the code changes via svm will now make the mmi 3g coding permanent
    5 2 0
  1. Even Lower Emissions For Latest Audi A4 Petrol And Tdi Models
    Last Post: 14-07-2008, 12:34 PM
  2. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
  3. Further Audi A5 Models Now Released
    Last Post: 25-08-2007, 06:49 PM
  4. Power boost for Audi TT models
    Last Post: 06-08-2005, 07:46 PM
  5. Audi launches efficiency drive with New A6 FSI models
    Last Post: 23-05-2005, 07:34 PM
