Thread: ipod confusion audi models
Page 20 of 36 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 356
  1. Re: ipod confusion audi models
    May 2007
    knee deep in clunge
    14 Post(s)
    Now connect the ami unit to the multi plug on the retro fit loom and connect your vag com
    go to address 56
    go to function 07 code control unit then open up the long code helper and change byte 11
    Attachment 6765
    go to address 19
    go to installation list and scroll down until you see media position 3
    tick the box and save
    Attachment 6766
    go to auto scan and run it then clear down all fault codes
    connect your ipod and and then wait a few mins
    select the media button on your radio and you will see the icon for AMI
    select it and play
    the picture shows empty because no ipod connected but the ami selection will light up and list the name of the ipod etc
    If everything is working reassemble and ask your local audi dealer to make the code changes permanent by connecting vas 5051/2 online connection and sending the reto fit conversion svm code to the fazzet server otherwise any work shop visits were the vas diagnostic is connected may well wipe the code changes plus the server needs the feed back to see the spec for future workshop actions
  2. Re: ipod confusion audi models
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by pform View Post
    I just had the confirmation from 2 audi gargaes that the Ipod Nano doesn't get recharged whilst docked in the gloves box port! I'm gutted! They said in brief that these Ipods have an update softwares whilst Audi didn't keep it up! One dealer told me that there sld be an adaptor to allow for the nano to get charged, tho they advised me to get a previous model of Ipod to quick fix the problem...Has anyone got advices on this? Thanks
    There is currently a adapter cable for gen 4 as the voltage needs converting from 12 volt to 5 volt.I will post the part number for the lead
  3. Re: ipod confusion audi models
    8 Post(s)
    Quote Originally Posted by a8 tech View Post
    Issac here you go,contact the dealer for the date of production
    Build week 22/07 pr number 7d3,8yq up to build week 44/07 ami kit 4E0 057 786B includes fitting instrucions
    Build week 45/07 till build week 21/08 ami kit 4E0 057 785D includes fitting instrucions
    WIRING HARNESS 4F0 051 592A fits both units control units
    Adapter cables
    4F0 051 510 C 3.5mm
    4F0 051 510 H Mini-USB
    4F0 051 510 G USB
    4F0 051 510 L iPod All models built before cw22/08
    4F0 051 510 K iPod All models built from cw22/08
    Do you know if this would be the same for a 55 plate (oct 05) A6 3.0 tdi quattro, same setup MMI High with sat nav, and 6 cd in glove box.
    MMI updated itself after I loaded the 2009 Nav dvd.
    Paul
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  4. Re: ipod confusion audi models
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes it should be fine but check with your local audi parts as the numbers may have super seeded.
    The nav update only updates the nav head unit, to update the MMI you need to flash the system via the 6 disc cd player.
    Select radio then press and hold set up and return until you see the engineering menu then click on the first setting to display the current software configuration
  5. Re: ipod confusion audi models
    Oct 2009
    Ipswich
    Hi A8,
    I'm new here and I really hope you can help me. I have scoured the internet to find an answer to my question but have failed to find a clear answer in plain english. So, I'm really hoping that you will be able to help me, providing you haven't lost the will to live yet with all these questions
    My wife has just bought a 2004 reg A3 2.0l FSI and it has a single din Audi Concert head unit with Bose speakers and Bose coming up on the screen when you turn it on. The car has no steering wheel controls.
    She has the latest Ipod nano (4th generation) and she wants to play it through her head unit.
    So, what on earth do I need to buy her in order for this to happen? Any links to an ebay item or such like would be much appreciated.
    Many thanks indeed
    Andy
  6. Re: ipod confusion audi models
    May 2007
    knee deep in clunge
    14 Post(s)
    Hello Andy
    Two options I would recommend
    audi IPOD kit which retails around £100 but you need the gen 4 additional lead
    How it works
    iPod preparation connects via the CD changer controls and is controlled in the same way; using the buttons on the radio or navigation system with MMI operating logic. This prevents the simultaneous operation of a CD changer and iPod adapter, as they share the same radio connection.
    Existing playlists on the iPod are identified as CDs and displayed as CD1-CD5 in the changer controls. All tracks stored on the iPod are identified as CD6. The iPod preparation is unable to process information stored on the iPod for the artist, track, album and genre, but the current playlist, the current track and the track duration will appear in the radio display or navigation system display with MMI operating logic.
    dension
    http://www.dension.com/products.php?productID=9
    the problem with the gen 4 nano is the charge circuit and for the Audi kit you need additional cables, nit sure about the dension but the nano charge circuit differs from the earlier gen Ipod
    I will check the gen 4 lead part number and cost
    Hope that helps
    Regards A8
  7. Re: ipod confusion audi models
    Oct 2009
    Ipswich
    Thats excellent help A8 thanks. I will probably go down the Audi ipod kit route so any part numbers will be very much appreciated Are they something I could buy online do you think or should I just go to an Audi dealer and ask for them?
    Many thanks
    Andy
  8. Re: ipod confusion audi models
    May 2007
    knee deep in clunge
    14 Post(s)
    Best bet, pop into Audi and ask for the ipod kit for your vehicle but remind them you have a nano gen 4 so you need the additional 5 v lead.The part number can be found on etka or using elsa pro tpi.The Technical product information document addresses the gen 4 charging issue but unfortunately I don't have the document to hand.Regards A8
  9. Re: ipod confusion audi models
    Oct 2009
    Ipswich
    You have been an imense help. Thank you for your time, its very appreciated
  10. Re: ipod confusion audi models
    Oct 2009
    Hereford
    Hi - Please, has anyone had any problems fitting a Denison 500 Ice Link Dual F.O.T. I have an 2005 A6 with MMI Basic (red one) and a single CD player (not a multi-changer). I have fitted it with option 2 in the following instructions and joined the red/blue wire from the existing CD player.
    http://enfigcarstereo.com/shopsite_s...30_01_2008.pdf
    However the unit seems to have a power problem as it comes on for about 30 seconds then powers off. I can keep pressing the reset button but it keeps switching off. Whichever way i put the switch - I still only get the existing CD until it powers off. Sometimes i loose the sound too.
    So have i just configured it incorrectly AND/OR could the unit be faulty?
    Pulling hair out now - All help gratefully received.
    Thanks in advance
    Dave
  1. Even Lower Emissions For Latest Audi A4 Petrol And Tdi Models
    Last Post: 14-07-2008, 12:34 PM
  2. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
  3. Further Audi A5 Models Now Released
    Last Post: 25-08-2007, 06:49 PM
  4. Power boost for Audi TT models
    Last Post: 06-08-2005, 07:46 PM
  5. Audi launches efficiency drive with New A6 FSI models
    Last Post: 23-05-2005, 07:34 PM
