Thread: not starting problems
  1. not starting problems
    Aug 2008
    hi there, i have a golf mk4 tdi pd engine. its parked over night on my drive which is pretty steep. sometimes when i try starting it, it will not start unless pump the pedal 3-4times then it will. recently i have noticed a noise coming from the in tank pump (its like a juddering noise) it does it when you turn the ignition on (not when engine running) mainly when your parked on a slope. i have just changed the fuel filter and has had no effect.
    i,ve been to a couple of local garages and i got told that either the pumps on its way out or i could have a leaky injector seal. ( would i not have diesel in my oil if i had a leaky injector)
    if i had either of these would they show up if i had it plug in to a computer
    thanks for reading would be grateful of any suggestions thanks dave
  2. Re: not starting problems
    Belgrade,Serbia
    hi, people fro those garages were right about possible faults. the only thing is that you have to dtermini the right one. as fpr yhe pedal pumping it has no effect. as for diesel in the oil, well that is not large amount of diesel that gets in the cilinders but enough to reduce pressure that is needed for starting. when you start the engine is it working normal or is it juddering for few seconds. and take a look at exaust for white or blue smoke
  3. Re: not starting problems
    Aug 2008
    hi thanks for your advice, there is no smoke from the exhaust when running it looks fine. once it starts it runs fine.any other ideas thanks dave
  4. Re: not starting problems
    Belgrade,Serbia
    what year is the car and what is the engine letter code?
  5. Re: not starting problems
    Aug 2008
    53 plate ATD
  6. Re: not starting problems
    Belgrade,Serbia
    I would change injestor seals and that should sort the problem out. I had two ATD engines last week with same problem.
  1. Please Help 1.9 t4 starting problems!!please help!!!
    By badboy123356 in forum The Commercial Range
    Last Post: 27-06-2008, 03:13 PM
  2. starting problems
    By tick73 in forum 80 - 90
    Last Post: 25-02-2008, 10:02 PM
  3. Problems starting
    By Springer in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-02-2008, 02:06 PM
  4. Starting problems with 1.4cl
    By audi bwoy in forum Polo - Derby - Lupo - Fox
    Last Post: 04-02-2008, 02:46 PM
  5. Starting problems PLEASE HELP
    By shakman83 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-08-2007, 11:04 AM
