Thread: whats going on excessive diesel usage!
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. whats going on excessive diesel usage!
    Filled up to the top,from shell (86.9 pece per litre) drove nice and nomal(no heavy right foot used) did 100.3 miles,went back to shell cost me 19.00 pounds! to fill up again!
    Whats going on,new temp sensor fitted fully serviced,it does take a few seconds to start,but only sometimes weather engine is hot or cold,will this make a difference? plenty of power in the car. Im sure it should of used no more than 10 pounds.
    HELP! A4 TDI 130BHP AWX ENGINE 2001 (B6)
    Dec 2006
    What MPG does the trip computer say you are getting as an average?
    it dont,mine is the standard 130bhp a4 without multifunction,ive set the trip to "0" and done 100.3 miles and filled up. ive been told it maybe the thermostat opening tooo early??????????
    Dec 2006
    Oh sorry, I didn't realise you could get them without the DIS system. And I thought my SE was basic!!!
    you have dis,and leather wheel,these are the only differences.
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Well, roughly you must have used about 23 litres of diesel then (£19 @ 86.
    9ppl) Which then means it must be about 5 gallons, meaning 20mpg. That's shocking for a diesel, even one running a bit badly.
    Might sound silly, but on the first fill-up, was it brim full, and then brimmed again - just to ensure comparability (tell, I do auditing?.... )
    Other than that, see if you can get your car vagcom'd or plugged in at a dealership to see where your engine may be having issues. I can do this, but it means a trip to the end of the M5.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
    did a full scan on vag-com...no faults found. What issues? it runs great,sum say change maf,and 1 says change thermostat.
    May 2006
    Well, the MAF and stat must be OK, as the car isn't reporting any issues with them through vag com. Has the service done anything I wonder? Wasn't a cambelt service was it?
    Maybe try some fuel additive to clear out the system a bit? Still, I'm shocked by 20mpg....
    Maybe try some fuel additive to clear out the system a bit? Still, I'm shocked by 20mpg....[/quote]
    do the fuel additives work, i seen redex in my local store, but wary of putting it into the tank case it goes B A N G ! ! ! ! ! LOL
    May 2006
    I'm a devotee of using Millers Diesel Power PLus in mine - every tankful. About to get some Millers Diesel Sport 4 - a new additive aimed at the more modern TDI engines. Meant to give excellent results.
  1. A3 excessive disc wear
    By Fazer in forum Audi A3 - Archive Topics
    Last Post: 20-08-2007, 08:25 PM
  2. Excessive front tyre wear
    By ColinT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-05-2007, 12:32 PM
  3. Excessive Brake Travel
    By jay77 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-04-2007, 10:20 PM
  4. VR5 excessive oil usage
    By seemiles in forum Passat - Archive Topics
    Last Post: 27-03-2007, 12:46 PM
  5. Excessive HC content in emissions.
    By H. Macari in forum 80 - 90
    Last Post: 16-02-2006, 06:39 PM
