Thread: Help wanted re ESP dashboard light
Results 1 to 10 of 11
  1. Angry Help wanted re ESP dashboard light
    Aug 2008
    Hi everyone,
    I am new to these forums and also to VWs so please forgive my ignorance. I am a pensoiner and struggling with the problem below. Any help, advice etc will be much appreciated.
    I have a 2004 Touran and the ESP lwarnng light shows permanently on the instrument panel. Recent diagnosis by VW dealer advises new ABS sender required; estimated cost £1500, yes £1500, including VAT and fitting (3.7 hrs), can anyone offer advice and help?
  2. Re: Help wanted re ESP dashboard light
    Southern County Softy
    20 Post(s)
    Get someone with vagcom to scan for faults,clear them and see if it comes back.
    It might be a dirty wheel sensor.
    The dealers are taking the p*ss.
    A4 2.5 tdi QS (mapped)
  3. Re: Help wanted re ESP dashboard light
    Jul 2007
    Near Maidstone, Kent
    That is a huge expence!
    Although the light you have on and the fault code they have read to match and make sense. I would be inclined to give the connections a clean and a squirt of WD40 to see if it is just a connection problem.
    As the sensors are down by the wheels, they are subject to a lot of dirt etc.
    I would agree with kite, once you have done that, you could find someone local to you with VAG-COM who could try and clear the fault for you to see if it returns.
    Worst case, it might still need changing, however, I can't see it being a difficult job and could be easily done yourself if you can find the sensor cheaper somewhere else.
    I hope this helps.
    Rob
    Unauthorised and unapproved commercial advertisment removed as per forum rules... Please read the rules...DO NOT post any commercial details!
  4. Re: Help wanted re ESP dashboard light
    Aug 2008
    Thanks for the advice so far guys. I live in west Suffolk near Bury St Edmunds, do you know of anyone in my area who could possibly help?
  5. Re: Help wanted re ESP dashboard light
    Jul 2007
    No, not really I am miles away from you, otherwise I would help.
    Perhaps have a look at the locations list on here?
    Rob
  6. Re: Help wanted re ESP dashboard light
    Aug 2008
    Hi Guys,
    I may have indvertently misled you all. The actual fault is 0201 Sender ABS Control Unit and not simply an ABS sender.
    The VW part no quoted is 1K0 614 517 H BEF.
    Does this shed any more light on the problem?
    A local garage owner suggests that it may be possible to repair the original unit, does this sound feasible?
    I will report more news as I have it.
    Thanks everyone!
  7. Re: Help wanted re ESP dashboard light
    Aug 2008
    Folks I now have more information.
    If you are tuned into this thread Crasher perhaps you can throw some more light on this.
    Fault code read:-Fault 01435 (or 01453 not sure) but read as Brake pressure sensor 1 - electrtical fault in circuit - G201 ABS Control Unit.
    I have also established many other Tourans and golfs have been having this same issue.
    On a related site someone is trying to gather data to put numbers on it.
  8. Re: Help wanted re ESP dashboard light
    Sep 2008
    Hi, could you point me in the direction of the related site please
  9. Re: Help wanted re ESP dashboard light
    Sep 2008
    I have the same problem on my 2005 Golf and VW have quoted me £1482 for replacing the ABS control/hydraulic unit.
    I would also be interested in the site that Territouran referred to. However, I am aware of some other instances of this problem. Here are the links:
    http://uk-mkivs.net/forums/t/162832.aspx
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=39900 (I have been contributing to this thread).
    Tim
  10. Re: Help wanted re ESP dashboard light
    Aug 2008
    The site I referred to previously is currently only collecting data on Tourans, but the numbers are growing.
    Perhaps through this forum and possibly the MKIV forum, others could collect data on Golf ESP/ABS problems and other VW models. Then we could put the whole picture together.
    Perhaps the moderators have an idea of how best to do this, and they could make some suggestions?!
    Someone has suggested that we should provide all this data to the SMMT (Motor Manufacturers' Association).
    There are also many other threads on this topic if you search the pages or enter ESP or ABS in the search engine.
  1. Audi A4 Dashboard Instrument Panel Light Bulb Dash Light Fix
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2011, 08:39 AM
  2. Help.Hazard Light on Dashboard
    By pops11 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-02-2010, 12:06 PM
  3. Brake light indicator on dashboard
    By herbsegal in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2008, 03:51 PM
  4. ABS Light on dashboard
    By spritefzr in forum Audi A3 - Archive Topics
    Last Post: 25-04-2008, 05:30 PM
  5. dashboard light
    By chris954 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-02-2008, 08:42 PM
