Hi Brian,
It is difficult to diagnose, but worth getting the measured value blocks checked for the coolant temp sender, might be under fuelling it, also check for any vacuum leaks or air leaks.
We can do this for you if you require, would be an 1hr diagnosis.
Regards
Lee
VAGTUNE 01296 428324
