Thread: Performance/Sports Clutch - Golf TDI 130
  1. Performance/Sports Clutch - Golf TDI 130
    Mar 2008
    Hi all
    recently had my Golf mk4 TDI 130bhp re-mapped and i'm loving the changes! my clutch was on the way out anyway and predictably it slips around 2000 rpm when the turbo kicks in.
    i want to put a decent and durable clutch onto it rather than a standard and then same thing happens. Can anyone recommend a site to use to buy the clutch itself?
    J
  2. Re: Performance/Sports Clutch - Golf TDI 130
    Jul 2008
    I run a Superchips remapped 150PD and the clutch lasted to 145000 miles until the gearbox seal went. Replaced with genuine Vag kit and all is fine again.
  3. Re: Performance/Sports Clutch - Golf TDI 130
    Jul 2008
    this months volkswagen driver magazine (september 2008) in the adverts at the back page 65 has a article about the zf sachs replacement solid flywheel cover and plate as a upgrade for high torque chipped engines. no mention of price though.
    they do conversions for all the popular vw's petrol and diesel
    give them a ring on
    CBP 01748 831 200
    VCDS Full Version Hex+Can
    Elm-327
    ProScan v5.4 OBD
    EngineCheck OBD
  4. Re: Performance/Sports Clutch - Golf TDI 130
    135 Post(s)
    2026 Post(s)
    The clutch isn’t the weak point, it is the flywheel and solid flywheel conversions are OK as long as you don’t mind a noticeable decrease in refinement from engine vibration transmitted into the car.
  5. Re: Performance/Sports Clutch - Golf TDI 130
    norn iron
    if only i couldt get a solid flywheel conversion for mine there is a kit available for everyother bloody model of golf except for my 115 ajm
  6. Re: Performance/Sports Clutch - Golf TDI 130
    Mar 2008
    thanks for the ideas. it has done near on 100k miles over 5yrs and the biting point of the clutch is fairly high. would that indicate the clutch needs replacing? if so do i go standard or performance clutch? Any ideas??
    As the torque has increased a fair amount should i be risking a standard clutch?
  7. Re: Performance/Sports Clutch - Golf TDI 130
    135 Post(s)
    2026 Post(s)
    The clutch is very strong and reliable, being able to take 180PS and a 370Nm without seriously shortening its life span IF treated with respect. It is the flywheel which is the weak point and excessive slipping generates heat levels high enough to cause failure.
  1. sports/performance exhaust
    By JTDI in forum Golf MK5 - 2004 - 2009
    Last Post: 10-01-2008, 06:27 PM
  2. Slipping Clutch on Passat Sports Estate
    By philbee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-08-2007, 03:43 PM
  3. Sports Clutch
    By Jim The Crim in forum Bora - 1998 - 2005
    Last Post: 18-07-2007, 07:33 AM
  4. improving performance mk4 golf?
    By valley rower in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2007, 09:08 PM
  5. Golf performance increase?
    By Jay in forum Golf MK4 - 1999 - 2004
    Last Post: 17-01-2007, 05:02 PM
