Thread: caddy 2001 no glow light and wont start
  1. caddy 2001 no glow light and wont start
    Aug 2008
    hi everyone i have a problem with my caddy. I had a flat battery and i tried to jump start it but then there was no glow plug light and it would not fire. any clues would be very grateful, cheers
  2. Re: caddy 2001 no glow light and wont start
    Aug 2008
    I know that when I remove the glow plug relay from my fuse box the orange warming light does not light up maybe its worth changing the relay i dont think they cost much.
  3. Re: caddy 2001 no glow light and wont start
    shakeybee Guest
    i have a similar prolem with my 01 sdi caddy except sometimes the glow light doesnt come on, the engine will turn but not start. this happens every few days and sometimes wont start for days. vag program wont show any faults in the system. has anybody else had similar problems. any help figurin out wats gone wrong wud help a lot.
  4. Re: caddy 2001 no glow light and wont start
    Aug 2008
    will try that, thanx.
  5. Re: caddy 2001 no glow light and wont start
    shakeybee Guest
    caddytrauma
    i just replaced my 109 relay and all problems seem to be solved. the relay only cost €25. hope you get yours sorted.
  6. Re: caddy 2001 no glow light and wont start
    Aug 2008
    well I hadn't had time to have a look for a while and I went out one evening to have a look. thought i would turn the key on the off chance and guess what, started first time. any ideas on this
  7. Re: caddy 2001 no glow light and wont start
    shakeybee Guest
    caddytrauma -- if your engine is an SDI try replacing the number 109 relay in the fuse board under the steering column area. if its TDI im not sure if they use a different code but it controls the engine control/ecu. mine was behaving similarly it wouldnt start for five days then just started one morning. have no more problems now though.
  1. Please Help 1997 1.9 tdi vw sharan glow plug light on (not flashing) then won't start
    By jules n in forum Touran - Sharan - Caravelle
    Last Post: 12-09-2008, 09:53 PM
  2. Please Help 2001 caddy no coil light and wont start
    By caddytrauma in forum New Member Introductions
    Last Post: 24-08-2008, 09:51 PM
  3. 2001 s3 oil warning light wont go out
    By plumbershands in forum Audi A3 - Archive Topics
    Last Post: 04-05-2008, 07:38 PM
  4. 2001 Caddy - my first post
    By BlueCaddy in forum The Commercial Range
    Last Post: 05-03-2008, 08:29 PM
  5. Caddy van intermittent no start
    By nevm in forum The Commercial Range
    Last Post: 25-02-2008, 09:42 AM
