Thread: power steering fluid?
Results 1 to 8 of 8
  1. power steering fluid?
    London
    Hi there,
    I have got a 1999 a4 2.8 quattro and have noticed that the power steering fluid is low. I asked at halfords what fluid to put in and they said its audi,s own power steering fluid? Does anyone know if i can buy any other fluid as audi will prob charge a fortune for it. I did notice though that the fluid in there at the moment is a brown ish colour and normal power steering fluid is a red colour. Can anyone help.
    Cheers Mark.
  2. powersteering fluid
    Marcass power steering fluid only gets used if there is a leek in the system the fact your power steering fluid is brown may mean its either never been changed or it has a contaminate!!
    check is your steering noisy, graunchy do you get judder whilst turing the wheel?
    also its important to note that power steering fluid should be checked whilst the engine is running and before you check it move the steering lock to lock a couple of times then with engine still running check the level quickly. If you check the level any other way you will probably gat a false reading.
    If all else fails then as a precaution get the fluid changed i have used fluid from german swedish car parts for the last few years on all my vag cars and have never had a problem hope this helps for gsf follow the link bellow http://www.gsfcarparts.com/
  3. power steering fluid
    London
    Thanks for the advice. I will call gsf tomorrow as i looked at the website link you gave me and see they also sell parts, and i may need a cv joint for my 1999 2.8 a4 quattro.
    I live in leytonstone london, i dont suppose you know of a good but cheap garage in london that could change the cv joint and also look at my power steering fluid.
    Chhers Mark
  4. POWER STEERING
    SORRY MARK IM OVER IN HANTS AND WOULDENT TOUCH ANY GARAGE I DO ALL THE WORK I CAN MYSELF AND ANYTHING I CANT DO ON MY OWN I GET MY GOOD FRIEND WHO IS A MECHEANIC TO HELP ME OUT USING HIS WORKSHOP.
    BEST BET IS TO FIND YOURSELF A VW AUDI OR GERMAN SPECIALIST IN YOUR AREA THEY SHOULD BE ROUGHLY HALF THE COST OF VAG GOOD LUCK MPEP666
  5. power steering
    London
    Hi again,
    Ok thanks it was worth asking anyway, but once again thanks for your advice.
    Cheers Mark.
    Mar 2007
    I am also looking for info on power steering fluid having just bought some from Halfords - own brand LHM Plus Specialist Mineral Fluid. As handed out by a guy in the shop once he had checked their own info sheets but as it seems critical you use the right stuff want to make sure it is OK before i open the bottle to check colour - green?? and then find out it isnt what i need.
    Cheers TC
    Kettering, Northants
    You need VW/SEAT/Skoda/Audi G004000M2 mineral PAS fluid which is green. Available from dealers (Are the lower brands cheaper at retail than Audi dealers??) at about £7 per litre IIRC.
    Dec 2006
    only used the VAG fulid.. If you mix it, it will not bond and will cause air bubbles...
    Buy it from Audi.. its not much...
    RicKt
  1. 1999 Golf 1.9 TDi Power Steering Fluid Low
    By gazza57 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 12:36 PM
  2. Power Steering Fluid
    By s0niX in forum Polo - Derby - Lupo - Fox
    Last Post: 29-03-2007, 02:05 PM
  3. audi a6 power steering fluid loss
    By nigepet in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-01-2007, 09:32 PM
  4. Power steering fluid leak
    By tBoris in forum Audi A4 - Archive Topics
    Last Post: 19-09-2006, 10:12 AM
  5. Power steering fluid
    By passat guy in forum Passat - Archive Topics
    Last Post: 15-09-2006, 09:54 PM
