Thread: Noisey 2.0 fsi help please!
Results 1 to 10 of 12
  1. Noisey 2.0 fsi help please!
    Jun 2007
    hi people
    Got a problem with a 2004 a3 2.0 fsi wondered if anyone could help or may of heard of similar problems?
    On start-up from cold the car is great but once its up to tempreture i could only describe it as sounding just like a diesel,theres a low extra knocking noise that sounds like it may be coming from the timing chain end of the engine
    Now ive changed the oil and filter just to rule out issues there but still the same so ive taken off the cam cover to look for any obvious signs there and taken off the cover for the timing chain to look for any excessive wear etc and cant see anything really obvious but i can depress the cam chain fully down with my thumb anyone know if that is normal or does it sound maybe a little weak??
    Any help would be most welcomed as im really stuck now and really could do without a trip to the main *******s at the mo!
    Thanks guys
  2. Re: Noisey 2.0 fsi help please!
    May 2007
    knee deep in clunge
    14 Post(s)
    the chain and tensioner are very common and the tensioner is oil supply fed so when the engine is off there will be some movement but not a lot so the chain and the tensioner requires replacing
  3. Re: Noisey 2.0 fsi help please!
    Jun 2007
    Thanks a8 tech
    so do you think the chain and tensioner could cause a slight knock as apose to a "chain rattle"?
    thanks again
    Allan
    ps are you a vag tech by any chance?
  4. Re: Noisey 2.0 fsi help please!
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes but you can also Deactivate the stratified charge (dealer only) which will reduce hard combustion noise.Second qestion=yes
  5. Thumbs up Re: Noisey 2.0 fsi help please!
    Jun 2007
    Thanks does deactivating the stratified charge just reduce the performance slightly?(disabling the fsi itself) and can it be carried out by someone with a bit of know how using vag-com or is it a dealer only operation?
    thanks again
    Allan
  6. Re: Noisey 2.0 fsi help please!
    May 2007
    knee deep in clunge
    14 Post(s)
    vag com doesnt support flash updates but you can turn it off
    Deactivate the stratified charge as follows:
    1. Select self-diagnosis 01 engine electronics
    2. 11 code II, entry 10011
    3. 10 adjustment of channel 15 (homogenous lean), channel 16 (stratified charge outside idle speed), channel 17 (stratified charge at idle speed)
    The activation temperatures can be set in the individual channels. By changing the basic value to 255 the respective operating type is deactivate
    performance willremain the same but fuel consumption will increase
    there is also a flash update that only vas machines can implement so i adise you to use the dealer for the hole job and expect you to only pay 1 hours labour
  7. Re: Noisey 2.0 fsi help please!
    Jun 2007
    Thanks really appreciate your help think ill start by replacing the chain and tensioner and if still noisey maybe go up the deactivation route
    hope you dont mind me asking dont suppose you know any good techs in the north west that do a bit of work in evenings or wkends
    cheeers a8
    Allan
  8. Re: Noisey 2.0 fsi help please!
    May 2007
    knee deep in clunge
    14 Post(s)
    no i dont,i help people out but i only do retro fitting these days and of course i do it for the love and not the money
  9. Unhappy Re: Noisey 2.0 fsi help please!
    Jun 2007
    ok ta mate!
  10. Re: Noisey 2.0 fsi help please!
    Jun 2007
    dont know how a got the blue smilie there btw? dont take it as unhappy
  1. Please Help Help noisey tdi
    By jonathan bees in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-01-2012, 07:57 PM
  2. noisey engine 1.4 bca
    By seancorcoran67 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-04-2009, 07:53 PM
  3. Please Help Audi 80 16v Noisey?
    By sdk778 in forum 80 - 90
    Last Post: 20-06-2008, 10:29 PM
  4. Please Help noisey turbo
    By fella123 in forum New Member Introductions
    Last Post: 15-06-2008, 08:50 PM
  5. Noisey waterpump
    By Strutt in forum Golf MK2 - 1984 - 1992
    Last Post: 08-05-2008, 06:21 PM
