Thread: Toledo Climate Control
  1. Toledo Climate Control
    Jul 2008
    Bourne, South Lincolnshire
    Hi, I have just purchased a 2004 Toledo 1.9 TDI. The previous owner somehow managed to break the display screen on the climate control unit. I have just purchased a replacement climate control unit from an online scrap dealer, it is simply the control panel with screen and is very similar to a car stereo unit with a simple plug-in connector for the wiring. Does anyone have any idea how to replace this unit? I can't see any obvious way to remove it but guess the radio may need removing first somehow. The replacement unit has a screw hole either side, but this is behind the trim below the radio. I spoke to my local Seat dealer, they want £70 to fit it. Any advice would be much appreciated!
  2. Re: Toledo Climate Control
    Dec 2007
    Suffolk
    The unit is just like a radio, not sure how it comes out but it may need re coding with vagcom be fore it works with your car.
  3. Re: Toledo Climate Control
    Jul 2008
    Thanks, I never thought that it may need recoding but I wouldn't have thought it would if it already has an identical unit fitted. I will have a go at removing the unit this weekend and if I don't get anywhere I will ask my local garage. Its such a shame they don't do a Haynes manual for the Toledo!
  4. Re: Toledo Climate Control
    Jul 2008
    I managed to replace the damaged unit myself after figuring out how to remove it, it isn't too difficult and the new unit didn't need reprogramming, it just worked. If anyone else needs to undergo this let me know and I will give full details.
  5. Re: Toledo Climate Control
    Nov 2008
    Quote Originally Posted by TDI Phil View Post
    i would like to know as the bulb has gone inside mine and need to get it out , thanks andy
  6. Re: Toledo Climate Control
    Jul 2008
    Hi Andy,
    It's been a few months since I replaced this unit, but I think I remember how I did this!
    1. Open the ashtray, and undo the screw(s) inside. Disconnect the lead to the cigarette lighter and remove tray. You will now see screws holding the base of the trim in place, remove these.
    2. Next you need to remove the car radio. Mine is a CD unit which I think is pretty standard. To do this you need a special tool to push into the slots at the bottom, I however made my own using a hacksaw blade chopped in half. I then cut the width back on each with a grinder until they fitted into the slots. Push these in and the unit will pull out. I recommend not removing it completely incase it needs a pin number, therefore just pull it out half way and keep it connected.
    3. You should now see more screws, remove these.
    4. Now the trim should come away by carefully pulling and unclipping. I started at the top above the radio and worked my way down, it is a large piece of trim so be careful. You should be able to lift it around the radio easily and completely remove it.
    5. Once you have removed this you can undo the screws now visible at either side of the climate control unit. Now the unit will slide forward like a car radio. Disconnect all the connectors at the back, and the unit is out.
    I hope this helps, as I said it is a few months since I did this but I don't think I have forgotten anything!
    Cheers,
    Phil
  7. Re: Toledo Climate Control
    Nov 2008
    Hi Andy,
    Cheers,
    Phil
    thanks just need to wait till some milder weather and will have a go , usually service tractors and hate car electronics
    if something goes its always the hardest to get at ,part , and usually damn expensive for what it is
    having said that i love my toledo , far more sporty than the passat it replaced ,
    all the best andy
  1. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
  2. climate control
    By billiethezwerg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-06-2008, 02:09 PM
  3. Just an old tip for the Climate Control..
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-05-2008, 01:19 AM
  4. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  5. climate control
    By salty in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 28-12-2006, 10:18 AM
