Thread: Is there a service interval in Months for MK4
Results 1 to 10 of 18
  1. Is there a service interval in Months for MK4
    Nov 2006
    I bought a MK4 Gold GT TDi 130 from a non franchised dealer, the car was an ex lease car that had no service book, only the previous Franchised VW dealer print out.
    Can anyone tell me what the manufacturer recommended service interval says, I know is 10K or variable on the long life (mine isn't) but is there a time period stipulated?
    I have purchased a warranty with the car but have noticed in the small print that it must have been serviced at the manufacturers recommendations. Whats worrying me is that the last service, although done only 5000 miles ago, was about 18 months back and am worried that this may invalidate the warranty if there is a time period stipulated as well.
    Quote Originally Posted by d@ve View Post
    i had a similar problem when i purchased my gt tdi from a dealer too. the exact same issuue, but with the cambelt change which had exceeded its time period. general rule of thumb is that if you cover less than 10k a year an inspection service should be completed every 12 months. the way i service my car is oil change every 6k, major service every 12k, this is more than sufficient on the fixed interval service to be in accordance with the manufacturers guidline. if the car has gone more than 12 months without a major service, you ought to have taken this up with the dealer before taking delivery of the car. that said, approach them and discuss, if you get no joy, im sad to say you will have to take the responsibility of it.....
    its a sucker but its the small print that means the most. if you speak to your warranty and explain the situation, they may be able to advise you more
    Nov 2006
    Swampyland, UK
    Hi. Firstly - update your profile (UserCP) and add a signature with the full details of your car, including build model year (the 10th digit of your VIN), and engine code (three digits, usually begining with A**), found on the data sticker on the boot floor under the carpet; just like eshrules or mine. While you are noseying at the data sticker, look at the "PR" codes and search for "QG1", or any "*G1" codes, and tell us what you find.
    There are two servicing regimes. Firstly, there is the traditional "fixed" method, of upto 10,000 miles or 12 months, whichever comes soonest. Secondly, there is the newer "LongLife" variable servicing, of upto 30k miles (for a diesel, upto 20k mi for petrol), and upto 24 months, whichever comes soonest. The LongLife servicing uses an adaptive computer to constantly calculate and readjust the time and distance to the next servicing.
    If your car is on LongLife, as indicated by PR code "QG1", then you are perfectly within the manufacturers recommendations. Looking at the history you stated above though, of only 5,000 miles in 18 months, then that useage is way outside of the scope for LongLife servicing, based on VWs own recommendations.
    Regarding the lack of service book, go to a franchised VW dealer, with your V5 and proof of ID and they will order one for you (at a cost).
    Rgds
    Dec 2006
    Manchester
    Quote Originally Posted by Teutonic_Tamer View Post
    Rgds
    His isn't on the long life sevice....
    I'd have a word with VW, and explain the situation. If you service it with them soon, then they may honour the warrenty.
    Nick
    Nov 2006
    Swampyland, UK
    Quote Originally Posted by bora(ing) nick View Post
    Erm . . . how can you be sure? LongLife servicing was introduced (with some specific exceptions) accoss the VAG range from model year 2000.
    As the OP stated his car is a Mk4 Golf, these were from 1997 to 2003 (with some upto model year 2005). A Golf GT was a later spec, and the 130bhp TDI is a PD, so LongLife is highly likely, although I could be wrong!
    Dec 2006
    Manchester
    I'm not 100% either, but he said in a post further up the page (post no.1) that his wasn't on long life servicing....
    All the best
    Nick
    Nov 2006
    Swampyland, UK
    All the best
    Nick
    I've just re-read his original post again, and you're right. But I presumed the OP was told some piffle by the supplying non-franchised dealer. There are two slightly different issues; is the OPs car actually enabled for the LongLife servicing (which is where the data sticker PR QG1 comes in)?, and has it actually had any LongLife services (which can only usually be found from the original service book).
    The lack of service book, and the lack of non-franchised supply was why I questioned the actual service regime.
    My appologies if you thought I was having a dig at you!
    Rgds
    Nov 2006
    [quote]
    Engine code is ASZ
    The number is 3, but i've checked my log book and it was registered in Nov 2002.
    PR codes - if you mean all the 3 digit codes on that sticker then yes there is a QG1 code amoungst all the others.
    Ok thanks I'll contact them.
    2003 Passat 1.9 SE Sport TDI 130
    2002 MK4 Golf 1.9 GT TDI 130
    Nov 2006
    To clarify the servicing, it was done at 10K miles each time by a Franchised VW dealer whilst it was leased.
    It was then sold on to the non Franchised dealer I bought it from.
    if it was done every 10k, that sounds like fixed interval to me, so yuo should maintain the same standard. i do believe longlife doesnt really apply unless you are doing mainly m.way or long haul journeys anyway?
    cue teutonic.... you old fart LOL
  1. Service Interval Reset for Audi A4
    By duncan89 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2010, 10:18 AM
  2. Service Interval Reset
    By Seat Driver in forum Alhambra
    Last Post: 28-09-2008, 09:39 PM
  3. How to re-set Service Interval for 2000 Audi A6 1.8T SE AVANT?
    By fsazhar in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-02-2007, 04:14 PM
  4. DIS - Service Interval Display
    By Piez in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2007, 03:46 PM
  5. A3 Changing/Reseting Service Interval
    By walanis in forum Audi A3 - Archive Topics
    Last Post: 29-12-2006, 11:28 AM
