Thread: audi 80tdi belt tensioner
  1. Unhappy audi 80tdi belt tensioner
    littlekev Guest
    hi can anyone tell me how to change alternator belt tensioner?the pully which keeps tension on the ribbed belt on my tdi is shot to pieces and the belt just slips icant figure out how this comes apart any help or advice would be great.i think the pully can be bought rather than a complete unit
    Feb 2007
    Unscrew the nut in the center of the tension-wheel....easy!
    Nov 2006
    Oldham, Manchester, UK
    I've posted a similar question before and got a similar answer.
    My question now id, how does the tensioner wheel provide the tension for the belt? Surely there must be some other doohickey with spring in it that keeps the belt tight.
    '96 A4 1.8. For spares now
    '98 A4.........New headache
    Feb 2007
    Not in mine. I've got an Audi 80 Avant -94, and my tension-hickey is also blown to smithereenes. However by using a tyre-iron or equiv. you will be able to tighten it enough. Be aware to loosen the two 13mm nuts on the rear of the alternator...one is hidden behind the coolant-hose.
    Also barely loosen the nut in front, connecting the alt. to the frame mounted on the engine-block.
    Feb 2007
    Bristol
    Crushed the casing on the tensioner a few months back on my '95 80 TDi, and it was a knightmare to replace, due to the pre-tension built into the unit. Nothing a bit of elbow greese, common sense, and a 400mm socket extender bar for leverage couldnt fix
  1. AFN Aux Belt Tensioner
    By OxfordGTI in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2010, 10:42 PM
  2. Alternator Belt tensioner
    By Tezzel in forum 80 - 90
    Last Post: 12-09-2007, 08:48 PM
  3. Auxillary belt tensioner woes
    By porcher in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2007, 09:35 PM
  4. Timing belt tensioner problem
    By gbrownlee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-06-2007, 12:43 PM
  5. Info on Fan Belt tensioner
    By PeeJay in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-01-2007, 01:31 PM
