Thread: Water dripping from front of wheel arches
Results 1 to 10 of 13
  1. Water dripping from front of wheel arches
    Jun 2008
    I noticed tonight there was water slowly dripping from the very front outside corners of the car, kind of like the front of the wheel arches. There is no sign of water loss in the coolant tank. I looked under the wheel arches and it seemed very wet at the front.
    It rained yesterday so maybe could be something to do with that?
  2. Re: Water dripping from front of wheel arches
    Jun 2008
    Have you checked your car again after the rain has cleared and did you drive the car while it was raining and drive through any large puddles??
    Another possibility that springs to mind is check your windscreen washer bottle. This maybe damaged or a pipe from it has disconnected.
    If it ain't broke leave it alone!!!
  3. Re: Water dripping from front of wheel arches
    Jun 2006
    UK, Mids
    Check the plenum chamber where the battery is located isn't blocked and draining slowly.
    Otherwise it may be air-conditioning condensate draining.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Water dripping from front of wheel arches
    A, A
    Quote Originally Posted by snapdragon View Post
    I think this is your answer
    Just another B7 Estate
  5. Re: Water dripping from front of wheel arches
    Jun 2008
    Hope it's not the plenum chamber as VW said they checked it wasn't blocked when they fitted new servo a month or so ago!
    I take it if it's air con condensate its normal?
  6. Re: Water dripping from front of wheel arches
    Aug 2006
    How much did the servo cost.................i might need to get mine done!!
  7. Re: Water dripping from front of wheel arches
    Jun 2008
    I paid £800 at a dealer but I also had to have a new brake pedal and fitting plus a brake light switch (and the cost included initial diagnosis). I think if it was just the servo it would have been around £500.
  8. Re: Water dripping from front of wheel arches
    Aug 2006
    £500................i'm really getting worried now!!
  9. Re: Water dripping from front of wheel arches
    Jun 2008
    I really hope for your sake you dont need a servo! I had to get mine done within two weeks of buying the car privately! Absolute nightmare start to live as a Passat owner.
    Touch wood though, it has been a wonderful car since having it done!
  10. Re: Water dripping from front of wheel arches
    Aug 2006
    Just spoke to my VW dealer and they said that my 2001 passat 130tdi has got 2 outstanding recalls 1) clutch casing cover and 2) Plenum chamber.
    I explained that i have recently experienced braking problems and also smoke coming from the exhaust (sludge in engine), i told them that i think it is because of the plenum chamber collecting water and therefore linked.
    They said book the recalls and discuss with an adviser when i come in.
    Does anyone think i have a chance of them making right possibly the servo and engine oil?
    Any experiences?
  1. Polo dripping oil
    By VickyM in forum Polo - Derby - Lupo - Fox
    Last Post: 09-09-2008, 08:13 PM
  2. Rear flared arches for non RS model
    By BB08BBY in forum Chat - Anything with wheels
    Last Post: 28-04-2008, 10:18 PM
  3. Wide arches to fit Bora
    By definitivemale in forum Bora - 1998 - 2005
    Last Post: 01-04-2008, 05:19 PM
  4. Will Mk3 GTi Skirts and Arches fit Mk3 Estate?
    By rustylt2 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-09-2007, 09:13 PM
  5. water coming from the front wheel arch
    By nerrad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 11:13 PM
