Thread: passat 2006 internal rear photochromic mirror issue
  1. passat 2006 internal rear photochromic mirror issue
    Aug 2008
    My mirror does not dim anymore even if the green led is on.
    I know that front interior light switches (when turned on) and rear gear turn off the dimming (green led still on).
    Switches and connector inside the light chassis seem ok.
    The mirror was changed some time ago, but the problem remained.
    So it is not a mirror fault.
    What I know is that when the mirror was not working, after turning on one the interior lights, it worked again...very strange.
    Now this trick does not work anymore.
    Any ideas?
    Thanks.
  2. Re: passat 2006 internal rear photochromic mirror issue
    Aug 2008
    Solved!
    Maybe it was the ceiling lights connector not well inserted or one of the three light switches.
    When I moved (just little moves) the cable, I heared a little buzz from the left side of the engine: maybe a short circuit...
    Then I moved the three switches (little moves too).
    I turned on my rear mirror.
    Now it works! Wonderful!
    I think that one of the element I moved maybe it was not wel connected, so a disable signal was sent to the mirror.
    I hope this thread be usefull to anyone.
    When I went to my car dealer, he changed the mirror and he said he controlled cables...but still issues were present.
    My guaratee is ended since last february.
    I don't want to think how much money I should have spent to check again everything!!!
    Have a nice day to everyone!
    Stefano.
  3. Re: passat 2006 internal rear photochromic mirror issue
    Mar 2008
    North-East
    have just replied to your last post! as it is out of warranty it could be expensive, good luck
    Passat Estate Sport TDI 170 DSG/ Golf GT TDI 140
  4. Re: passat 2006 internal rear photochromic mirror issue
    May 2008
    Have I missed something?
    If your car is 2006 it would have a 3 year warranty, how did it expire last Feb
  5. Re: passat 2006 internal rear photochromic mirror issue
    Aug 2008
    Here in Italy, Volkswagen gives only 2 warranty years.
    Maybe VW thinks they are enought, I don't think so...
    Regards,
    Stefano.
  6. Re: passat 2006 internal rear photochromic mirror issue
    May 2008
    Yes, I did miss something apologies!!
  1. A6 Avant 2006 Rear Bumper Removal
    By daweller in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-05-2011, 08:03 PM
  2. How To replace rear view mirror
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-06-2008, 11:50 AM
  3. Please Help VW Passat reg 2006, tdi.
    By ak_wf1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-05-2008, 03:44 AM
  4. 2006 Rear indicator light
    By audigenerator in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2007, 09:02 PM
  5. Passat 2.0 tdi 2006
    By brianpriches in forum Passat - Archive Topics
    Last Post: 27-12-2006, 06:15 PM
