Thread: double speed indicators
  1. double speed indicators
    Oct 2007
    52 plate tdi . Indicator warning light flashes at double speed but external lights fail to flash , not happening all the time, hazzard flash no problem, any ideas please?
  2. Re: double speed indicators
    Southern County Softy
    20 Post(s)
    blown bulb or flasher unit
    A4 2.5 tdi QS (mapped)
  3. Re: double speed indicators
    omegadirective Guest
    Beat me to it!
  4. Re: double speed indicators
    Exeter
    Moisture has probably got into the bulb connectors. Check the bulbs for broken filaments then spray lots of WD40 into the connector and reconnect the bulb. Do this to all of them and then try the indicators again. If they still don't work it may be the flasher unit as mentioned above, if they do work you need to keep an eye on the bulb covers and lights to check for cracks or signs of water ingress!
    Hope this helps
  1. Double Din in Golf Mk4
    By andy_c_v in forum In Car Entertainment
    Last Post: 29-06-2008, 11:46 AM
  2. Replies: 2
    Last Post: 26-03-2008, 07:46 AM
  3. what about those double din stereos?
    By iany in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2008, 12:22 AM
  4. Indicators double blinking
    By Etch in forum Audi A3 - Archive Topics
    Last Post: 10-02-2008, 09:41 PM
  5. Can you replace 4-speed gearbox with 5-speed? Golf ryder 1.4
    By Finjamin in forum Golf MK3 - 1993 - 1999
    Last Post: 14-01-2008, 11:31 PM
