Thread: central locking problem
  1. central locking problem
    Aug 2008
    hi all brought an a4 1995 a few days ago all was fine until this morning when i went to lock the doors the driver side was the only one that locked?
    i have checked the fuses all are fine any help would be appreciated
    many thanks
  2. Re: central locking problem
    Jun 2008
    Mold
    If you noticed that the central locking pump was overrunning after you`d locked the doors then the impeller IMPLODES as it overheats.... Check it out in your boot.
  3. Re: central locking problem
    Aug 2008
    many thanks for reply here is abit more info if that helps
    hi there where in the boot would i find it cos i have looked in the boot and have not found anything i've took the carpet out ,
    i'm abit confused as the central locking was working fine on wednesday but when i went to lock the car on thursday morning when i went to the shop the only door that would lock is the door i used the key in none of the other doors would lock and i did hear a weird noise abit like a humming noise earlier on thursday morning but thought nothing of it at the time, could this have been an early sign that the central locking pump say was packing up any other help would be appreciated
  4. Re: central locking problem
    Aug 2008
    Quote Originally Posted by richie_jones View Post
  5. Re: central locking problem
    Jun 2008
    Mold
    Read this:
    http://www.audiworld.com/tech/elec.html
    scroll down to B5 Central Locking Pump Failure and Replacement
    hope it helps...
  6. Re: central locking problem
    Aug 2008
    many thanks for your help i found out it was the pump i have now got another one and now the central locking works fine, again thanks for your help
  1. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
  2. Question Another Central Locking Problem!
    By m_loades in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-07-2008, 02:51 PM
  3. MK4 Central Locking Problem
    By nickelly in forum Golf MK4 - 1999 - 2004
    Last Post: 06-05-2008, 08:28 AM
  4. Central locking problem!!
    By gizzy4mo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2008, 01:27 PM
  5. central locking problem
    By jonjon in forum Polo - Derby - Lupo - Fox
    Last Post: 24-02-2007, 04:54 PM
