Quote Originally Posted by Teutonic_Tamer View Post
Yebut - if you stick with OEM sports springs and dampers, with the 10mm lower ride height, it will have NO effect on increased ball joint wear, nor your undertray. VW wouldn't design a car which kept bottoming out on everyday roads!
The only thing that will wreck your undertray or sump, is if you drive like a fu%&ing ****** - and then, quite frankly, you deserve it!
i agree, 10mm is (relatively) nothing, especially on a bora as they have quite a high ride height as standard i believe? and as also quite rightly stated, VW wouldnt and couldnt design a car which caught on the underneath every 2 minutes
ps teutonic ill have a look m8, but i think ill stick with castrol
