Thread: A6 2.5tdi Quattro 98 power loss and hesitation
Results 1 to 9 of 9
Hybrid View
  1. A6 2.5tdi Quattro 98 power loss and hesitation
    Jun 2008
    so power loss on an A6 diesel question for a change
    Hi All,
    So still have my problem from before but now at least I know it is not the gearbox.
    Essentially the car can no longer accelerate past 3000rpm. It accelerates as normal, then you will feel the power drain away near 3000rpm then smoke will pour out the back of the car, if I continue to hold the accelerator or push it more the car will then dramatically lose power which feels almost like I am pressing the brakes.
    Now the car is also hesitating when starting off. I will be in drive and will pull away, the car moves very slowly and then suddenly surges.
    I have tried to listen to the turbo and notice that it starts fine and whistles, then there is a strange whooshing noise at higher revs, when I let go the noise goes away and the turbo whisles normally as it winds down.
    Not sure if that makes any sense. I connected VAG COM and it reported no faults.
    Any ideas much appreciated. Could it be a split in the hose. I was going to look tomorrow morning. Can anyone tell me where the turbo can be found in this engine.
    Thanks All
  2. Re: A6 2.5tdi Quattro 98 power loss and hesitation
    MikkiJayne Guest
    The turbo is at the back of the engine sitting in the middle of the V. On mine the outlet goes down below the right cylinder head, along the side of the engine, then drops down under the headlight in to the intercooler. Out of the intercooler on the other side, then in to the inlet manifold.
    There are a few rubber hoses to come loose in there. When one of mine fell off it ran out of steam at about 3k ish, but it didn't make any smoke because the ecu noticed that there wasn't any more boost.
    I think you may have a different problem though since yours is blowing smoke. That means its putting in too much fuel for the air it has. Hopefully someone else will have some ideas about why.....
  3. Re: A6 2.5tdi Quattro 98 power loss and hesitation
    london/ UK
    You could try disconecting the MAF and if it runs the same or better then the MAF is faulty. I also had a car wich had a blocked cat and i tried everything: new turbo, MAP sensor, MAF, boost control valve, EGR valve, etc. I would remove the cast piece from the turbocharger's flange to the exhaust downpipe. Soak them in lots of wd40 prior to removing, then take it for a spin. If it goes like ****, then its the catalyst...A quick fix its taking the car on the motorway and give it some stick(conect the turbo pipe back first !) and keep the revs as high as possible...Cleaning the turbocharger might also help...
  4. Re: A6 2.5tdi Quattro 98 power loss and hesitation
    Jun 2008
    ok thanks will give it a go. dont think its MAF as its only done 70,000 miles and had a new maf 20k ago.
  5. Re: A6 2.5tdi Quattro 98 power loss and hesitation
    Jun 2008
    tried the car with maf unplugged but cant tell how it runs as tiptronic box goes into immediate limp mode. the below is what I got after that from VAG COM
    VAG-COM Version: Release 303.1
    Chassis Type: 4B - C5 Audi A6
    Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 4B0 907 401 K 2
    Component: 0000AG D50
    Coding: 01004
    Shop #: WSC 02325
    3 Faults Found:
    00553 - Mass Air Flow Sensor (G70)
    27-00 - Implausible Signal
    00575 - Intake Manifold Pressure
    11-10 - Control Limit Not Reached - Intermittent
    00523 - Intake Air Temp Sensor (G42)
    30-00 - Open or Short to B+
    Readiness: N/A
    Address 02 -------------------------------------------------------
    Controller: 4B0 927 156 BH
    Component: AG5 01V 2.5lTDI RdW 9016
    Coding: 00000
    Shop #: WSC 00000
    1 Faults Found:
    18265 - Load Signal: Error Message from ECU
    P1857 - 35-10 - - - Intermittent
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D00
    Coding: 0273004284
    Shop #: BB 24334
    0 Faults Found:
    Address 08 -------------------------------------------------------
    Controller: 4B0 820 043 Q
    Component: A6-Klimavoll
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 4B0 919 930 P
    Component: C5-KOMBIINSTR. VDO D06
    Coding: 05460
    Shop #: WSC 00050
    IMMO-IDENTNR: AUZ7Z0W0682899
    0 Faults Found:
    Address 35 -------------------------------------------------------
    Controller: 4B0 962 258 H
    Component: Central Lock/Alarm D32
    Coding: 04814
    Shop #: WSC 00001
    4 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00956 - Key 2
    09-10 - Adaptation Limit Surpassed - Intermittent
    Address 36 -------------------------------------------------------
    Controller: 4B0 959 760 A
    Component: Sitzmemory D05
    0 Faults Found:
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 02325
    0 Faults Found:
    Address 56 -------------------------------------------------------
    Controller: 4B0 035 186 B
    Component: Radio D02
    Coding: 00017
    Shop #: WSC 02325
    0 Faults Found:
    End -------------------------------------------------------
  6. Re: A6 2.5tdi Quattro 98 power loss and hesitation
    london/ UK
    You either have a blocked cat or a jammed VNT mechanism on the turbocharger and the ECU does not like it. You can clean the turbocharger if you wish and take it from there...Cats are fairly expensive and i would not put an aftermarket one on my car, just genuine ! Good thing is a diesel in good shape does not need a cat for MOT as its there just to reduce smell and NOX...You could take the plastic cover off the engine and scan the engine controller, then go to Basic settings, ch 11 and watch if the rod from the turbocharger's actuator moves smoothly...up and down !
  7. Re: A6 2.5tdi Quattro 98 power loss and hesitation
    Aug 2008
    Quote Originally Posted by mjpleusch View Post
    Hi All,
    Thanks All
    Hello
    I'm Laszlo and one of my friend had same problem as yours.
    First remove and clean the manifold air pressure sensor(located at discharge on air cooler) and if it does not help replace the sensor.
    Without correct signal of this sensor the max rpm appr. 3000
    Laszlo
  1. Strange power loss 2.5TDi - help please!
    By Teflon in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2008, 02:31 PM
  2. 2.5Tdi Power loss
    By Redbus in forum 100 - 200 - Turbo - 100 S4
    Last Post: 20-04-2008, 06:51 PM
  3. 2.5TDI - Loss of power
    By JLLL in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-04-2008, 02:50 PM
  4. LOSS OF POWER a4 2.5tdi!!!!!
    By Bodferret in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-01-2008, 02:09 PM
  5. 2.5tdi loss of power
    By mopster in forum The Commercial Range
    Last Post: 26-05-2007, 10:37 PM
