Quote Originally Posted by gmm View Post
heya folks i had the same prob with my cd player ended up i had to change the yellow wire connection ito the y piece connection just swap those wires and it should keep its memory i think they are main feeds, and it should play from where you left off etc hope this helps
i can see you're a new member....welcome to the forum!
thanks for your input, but i think the problem the OP is having isnt related to the memory, the problem he has is to do with when he is turning his ignition off the player is ejecting the cd.....
