Thread: Interior lighting stays on - any ideas?
  1. Interior lighting stays on - any ideas?
    Aug 2008
    A6 2.5TDi Avant Quattro, 2000 . My interior light now stays on permanently when the switch is set in the middle position - front and rear domes and reading lights. I can switch them off with the front and rear master switches. I don't think it's a door actuator because the little picture in the middle of the dashboard isn't showing the doors as open. My first guess is that the delay timer has failed. Does anyone know where it is in the car, and whether there's any way of testing it out? Regards, Pete
  2. Re: Interior lighting stays on - any ideas?
    PLease chaeck you front passenger footwell is totally dry. If you lif the mats and ther is condensation under them of the carpet is atall damp them you may have water in your CCM caused by blocked drain holes in your Plemum Chamber. Regards Peter
  3. Re: Interior lighting stays on - any ideas?
    Aug 2008
    Excellent suggestion, particularly when you consider that I had a new windscreen fitted 2 weeks ago.
    No condensation under the mats, and no dampness in the carpet though. It's started working again this morning too, so this looks like one of those problems which is going to take a while to troubleshoot.
    Pardon my ignorance, but what is a CCM?
    Kind regards,
    Pete
  4. Re: Interior lighting stays on - any ideas?
    Convenience Control Module. It resides in a recess in the floor pan under the passengers footwell. Are you happy with the new screen. I had mine changed and the it is less tinted then the original. Regards Peter
  5. Re: Interior lighting stays on - any ideas?
    Aug 2008
    Thanks. If it starts happening again I'll have the carpets up and see what's going on.
    The new screen seems fine, and I hadn't noticed any less tint. It also has the major advantage of not having a foot-long crack across the driver's eyeline! Mine came from RAC Auto Windscreens, but I guess they all use the same supplier.
    Thanks for your prompt and helpful suggestions, it is much appreciated. This is a great forum.
    Kind regards,
    Pete
  6. Re: Interior lighting stays on - any ideas?
    Yes mine was RAC auto windscreens as well. Regards Peter
    By jollyjohn in forum Superb
    Last Post: 05-01-2009, 02:30 PM
  2. audi a4 interior lighting faults
    By jack10 in forum Chat - Anything with wheels
    Last Post: 29-04-2008, 10:11 PM
  3. Passenger Interior Door Light Not Lighting (MK4)
    By muchos04 in forum Golf MK4 - 1999 - 2004
    Last Post: 31-01-2008, 01:33 PM
  4. Interior lighting fault
    By mikelds in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-12-2007, 11:34 PM
  5. Control unit for interior lighting
    By packdude in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 06-12-2006, 08:02 PM
