Thread: fuel pumps
  1. fuel pumps
    Aug 2008
    north hampshire
    is it just my car or a silly design? when filling up with petrol, the pump nozzle has the be turned upside-down to fit in the fuel filler. if i dont do that then the pump always stops as if its telling me its full?!
  2. Re: fuel pumps
    omegadirective Guest
    Just your car! Lol. Mine fills up no problem at all. Do you always use the same pump/station? If so try another one...?
    If not, maybe you have something stuck on the inside that is triggering the nozzle sensor. Maybe have a look for that? If not, just enjoy the high off the petrol fumes!
  3. Re: fuel pumps
    Aug 2008
    north hampshire
    ive tried 6 maybe seven different pumps! all do the same! unless my fuel filler is upside down
  4. Re: fuel pumps
    Might be upside down then, but I thought they'd only fit in one way? Maybe not though. :s
    Someone on here should know whether it's an easy job to rotate it, if thats whats wrong.
    You must get some pretty strange looks at the pumps!
  5. Re: fuel pumps
    Aug 2008
    north hampshire
    i do! have to get the fuel pump hose over my shoulder! look like an idiot!
  6. Re: fuel pumps
    The first time I tried to fill up I couldn't get the pump to work.
    I have found that if you don't push the nozzle in all the way and maybe hold it back an inch it works.
    It's something to do with the shape of the inlet on the car causing splash back up the fuel pump nozzle. As the pump is feeling splash back it thinks the tank is full and so shuts off. If you keep the nozzle back a bit the splash back doesn't reach the shut off sensor so keeps sending fuel.
    Sorry for the many innuendos throughout this post.
  1. Question 1995 Golf VR6 fuel guage not working + fuel filter location
    By damo1982 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-06-2008, 10:04 PM
  2. 2.0tdi water pumps - plastic or metal?
    By greg123 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-05-2008, 05:55 PM
  3. Which Engines/Fuel Pumps can handle Vegetable Oil Mixes?
    By gavin44 in forum Chat - Anything with wheels
    Last Post: 13-05-2008, 12:21 PM
  4. Passat 1.8 Oil pumps
    By muddy in forum Passat - Archive Topics
    Last Post: 29-12-2007, 11:13 PM
  5. High Fuel consumption/Strange Fuel gage
    By mkpp786 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-11-2006, 01:53 AM
