Thread: golf mk 4 warning lights
  1. Unhappy golf mk 4 warning lights
    Aug 2007
    lancaster
    Hi i have a 52 plate golf tdi to day for no apparent reason both ABSand EPS lights came on and have stayed on. Anybody help. anybody got a piccy of abs module and abs sensor
  2. Re: golf mk 4 warning lights
    try the search facility.
    the same fault was discussed only a couple of days ago,on an a4 i believe.
    regards,
    stewy.
    4th cog,--two to go
  3. Re: golf mk 4 warning lights
    Cheshire, or my A6
    Check the rear brake lights first of all !
    Paul
  4. Re: golf mk 4 warning lights
    Jan 2008
    Had the same on my 1.8t AUM, both lights illuminated and very ocassionaly the ABS would kick in at low speeds just before I would come to a stop. Long story short, it was the front nearside ABS (speed sensor or whatever it is called). Replaced that about £20ish and all has been well ever since. HTH
  5. Re: golf mk 4 warning lights
    Aug 2008
    Hereford
    Have a look under the flap on top of the battery aswell, there are three 15A fuses, they tend to either burn out or the ends corrode, its these three that are in link with the module.
  6. Re: golf mk 4 warning lights
    131 Post(s)
    1976 Post(s)
    Or how about using the diagnostic facilities provided by the manufacturer and having a code read done which will tell you exactly what is wrong with it, or am I just being obtuse?
  7. Re: golf mk 4 warning lights
    Aug 2007
    lancaster
    correct your being obtuse
  8. Re: golf mk 4 warning lights
    Cheshire, or my A6
    Quote Originally Posted by david leslie View Post
    So have you checked your brake lights ?
    If they are ok I recommend a fault code read rather than changing parts for fun.
    Paul
  9. Re: golf mk 4 warning lights
    Aug 2008
    Hereford
    01276
    ABS Hydraulic Pump - V64-
    Signal outside tolerance
    Sporadic.......
    as per VAG 1551B
    All you need to do is on top of the battery, is the ABS fuse box with 3 x 15A fuses, remove the three fuses on the right, either replace them or clean them up using wd40 and soft emery paper...they suffer from slight corrosion / burring and this give you the SPORADIC fault. if it was abs pump failure, it wouldnt be sporadic.You'd pay £580 for an ABS pump, when you'l still have the 3 fuses causing ur probs
  1. Golf Dashboard Warning Lights
    By django in forum Golf MK5 - 2004 - 2009
    Last Post: 06-06-2008, 10:37 AM
  2. warning lights mark 4 golf v6 4motion
    By moss1985 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-12-2007, 11:58 PM
  3. V5 Golf warning lights
    By Rudge in forum Archive posts
    Last Post: 09-11-2007, 09:14 PM
  4. Re-setting Dash warning lights On Mk V5 Golf
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-06-2007, 05:50 PM
  5. mk4 golf warning lights
    By malc in forum Golf MK4 - 1999 - 2004
    Last Post: 27-10-2006, 07:03 PM
