Thread: T4 flashing oil light SOLVED!
  1. Thumbs up T4 flashing oil light SOLVED!
    Just a bit of info for anyone whos got what seems to be quite a common problem of the oil light continuously flashing even though everything is actually fine.
    My 1998 T4 1.9TD seems to have had all the electrics in the engine bay broken by previous owners when I got it. Both the oil pressure switches werent working, I replaced them hoping that it would fix the oil light. There was a slight difference when the engine started (light stayed on for a second or two), but it kept flashing. I had a poke around for other things but had no joy and its been flashing for the last few months.
    Today I was changing the oil and noticed that the two thin wires that plug into the alternator (red and blue) had completely broken inside the cable cover that comes down from the main wiring loom. Ive just soldered them back up and now my oil light does what it shoud do, comes on until the engine is started then goes out!
  2. Re: T4 flashing oil light SOLVED!
    Sep 2007
    east ayrshire
    i will try this tomorrow as my light is driving me mad. it is worse since i changed the oil and filter so i may have moved something when working. where is the best/easiest place to fit an oil gauge and any ideas on pressures on a 2.5tdi 03 plate
    regards
    jim
  3. Re: T4 flashing oil light SOLVED!
    hi ive got a 96 1.9td t4 ive got flashing oil light,battery light never works, sometimes flats the battery,ive tried all sorts,i remember having a sim" prolblem with a audi 1.8 ended up being dash board problem,ill change dash on t4 and see if that cures oil light and batt light, im 99% sure it will cure it,????
  4. Re: T4 flashing oil light SOLVED!
    i have a similar problem......i start my engine (2.5 tdi) and oil light comes on and buzzer of doom beeps 3 times.....any ideas???? also, my rev counter doesnt work but sometimes (when near the sea) the rev counter works again and the oil light goes out!
    please someone help me!!!!
  1. Oil light flashing
    By betambeau in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 10:49 AM
  2. Oil light flashing
    By montymole in forum Touran - Sharan - Caravelle
    Last Post: 10-03-2008, 01:34 PM
  3. A6 Yellow ABS Light And Flashing Red Brake Light
    By mikekirchner in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-01-2008, 08:15 PM
  4. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 09:26 PM
  5. ABS light on with flashing red brake light
    By P471 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-10-2007, 06:02 PM
