Thread: Rattles in drivers door
  1. Rattles in drivers door
    Dec 2006
    Over the last 6 months my A4 developed a really super annoying rattle in the drivers door. It was so bad you could control it using the accelerator pedal. Press the pedal to move the car forward it would rattle, then release the pedal to enduce engine breaking and it would go again!
    I took off the inner door panel which was surprisingly easy and thought I found the cause of the problem (a very squeaky, noisey connector to the switch that turns off the internal alarm sensors. I secured this fairly well so it would't move any more. I also noticed that some of the plastic spring clips were broken, so I glued them back together and used them again.
    At first I was utterly delighted! The noise had gone. But now it's back! Any ideas?
    I did thnk about taking the panel off again, installing new retaining clips, lubing up the mating surfaces with silicone lube. Not sure this will work though.
  2. Re: Rattles in drivers door
    Mar 2007
    Sorry this is no help to you but my A4 has a rattle which sounds as if it coming from near the small speaker just below the window at the front end of the door. I've been putting off looking at it as I've never been very successful at replacing door panels (a long time ago). Can you give me a few tips on how you went about removing and replacing the panel.
  3. Re: Rattles in drivers door
    Dec 2006
    http://www.audiforums.com/forum/showthread.php?t=8719
    I used this guide, annoyingly the piccies seem to be missing now! It was very easy to do.
  4. Re: Rattles in drivers door
    Mar 2007
    Thanks, I'll try that one weekend when it's not raining.
  5. Re: Rattles in drivers door
    Mar 2007
    Lancashire
    Quote Originally Posted by skymaster View Post
    Is it coming from the door or the frame? I had a rattle that turned out to tbe the window frame rubber making what sounded like a rattle. Some rubber care helped that.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  1. Drivers door not right, not the pins.
    By exup in forum Golf MK3 - 1993 - 1999
    Last Post: 04-08-2008, 01:17 PM
  2. Please Help Drivers door
    By mikemate in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-05-2008, 11:05 AM
  3. A3 drivers door
    By butler2.8i in forum Audi A3 - Archive Topics
    Last Post: 06-05-2008, 10:03 PM
  4. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  5. Golf MK5 Door wind noise and rattles
    By tony444 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-05-2007, 03:28 PM
